Hi, Iβm a big fan of PlatformIO especially because it worked out of the box, when I tried it the first time.
That was like 8 month ago. I work with ESP32-S2, Arduino framework and I have independent code that I want to test with unity on windows (so I can debug comfortably)
This test I compile for platform = windows_x86
with test_build_src = true
(I also tried test_build_src = yes
). This is supposed to add all the cpp files in the test directory and complete my test. It used to work but now after a break of 5 month (and probably an update), it doesnβt compile the files int the test folder anymore. And I get a linkage error:
undefined reference to WinMain@16
It is the expected consequence when the test files are omitted by the compiler.
Can anybody tell me, why the compiler is ignoring the test folder?
config file:
[env:Windows_unity_tests]
${env.build_flags}
-I include/utils
-I include/Extensions
-std=c++11
build_src_filter =
${env.src_filter}
-<main.cpp>
-<arduino>
bblanchon/ArduinoJson@^6.19.4
arduino-libraries/NTPClient@^3.2.1
Can you post the file structure of your project? (tree <your projectdirectroy>
Thank you for the answer!
The digest of my tree is below. main.should.cpp
contains the test main()
. main.cpp
contains the regular main but is removed from the compilation via the configuration.
C:\Project
β .gitignore
β platformio.ini
β workspace.code-workspace
β
ββββ.pio
etc...
β
ββββ.vscode
etc...
β
ββββinclude
etc...
β ββββdriver
β β Driver_AdcPin.hpp
β β Driver_Spi.hpp
β β Driver_TickTime.hpp
β β Driver_Time.hpp
β ββββEVSE
β β ChargingHsm.hpp
β β CpModeHsm.hpp
β β WifiConnection.hpp
etc...
β β
β ββββwin
β WProgram.h
β
ββββlib
etc...
β
ββββsrc
β β main.cpp
β β
β ββββarduino
β β Driver_AdcPin_Arduino.cpp
β β Driver_Spi_Arduino.cpp
β β Driver_TickTime_Arduino.cpp
β β Driver_Trace_Arduino.cpp
β β
β ββββEVSE
β β CpModeHsm.cpp
β β
β β
β ββββwin
β Driver_Spi_Win.cpp
β Driver_Time_win.cpp
β Driver_Trace_cmd_win.cpp
β
ββββtest
ChargingHsm.should.cpp
CpModeHsm.should.cpp
main.should.cpp
This folder structure is not valid, PlatformIO requires you to put the code files for each test unit in a new directory starting with test_
. This is documented in point 3.
https://docs.platformio.org/en/latest/advanced/unit-testing/structure/best-practices.html
Also see official example
@maxgerhard: I would like to apologize sincerely for starting this post and causing troubles. Can it be deleted? I feel deeply ashamed for doing a basic/foolish mistake and for blaming PlatformIO for it:
I have realized that I forgot to call the Test command in the Advanced section.
I called Build instead and it always gave me the same issue.
As for the test structure: it doesnβt really need the test_* sub folders if there arenβt multiple test suites. But that is only a detail. (If you looking at this post as a solution, look also at the post above from maxgerhard pointing out the existing examples for tests.)
Again, please accept my apologies for not using PlatformIO correctly - problem solved / case closed
