I am seeing a strange bug, where the serial connection to an AVR processor
- works for the terminal,
- works for avrdude called from the command line,
- does not work for avrdude called via pio run.
I have PlatformIO, version 4.3.4 on a Windows 10 machine, using Visual Studio Code
The microcontroller is an ATmega324PA on a custom board, with Optiboot 8.0 set for 57600 Baud
Running the Serial Monitor works:
Executing task: C:\Users\bernd.platformio\penv\Scripts\platformio.exe device monitor <
— Available filters and text transformations: colorize, debug, default, direct, hexlify, log2file, nocontrol, printable, send_on_enter, time
— More details at Redirecting...
— Miniterm on COM10 57600,8,N,1 —
… some output from my AVR program …
Running the avrdude version that comes with Arduino from the command line works:
“C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.exe” -C “C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf” -p atmega324pa -P COM10 -b 57600 -c arduino -v -Uflash:w:.pio\build\avr\firmware.elf
avrdude.exe: Version 6.3-20190619
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf”
Using Port : COM10
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega324PA
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude.exe: Device signature = 0x1e9511 (probably m324pa)
avrdude.exe: writing flash (23750 bytes):
Writing | ################################################## | 100% 18.58s
Reading | ################################################## | 100% 20.18s
avrdude.exe: verifying …
avrdude.exe: 23750 bytes of flash verified
But PlatformIO:Upload does not work
Looking for upload port...
Use manually specified: COM10
Uploading .pio\build\avr\firmware.hex
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
System wide configuration file is "C:\Users\myname\.platformio\packages\tool-avrdude\avrdude.conf"
Using Port : COM10
avrdude: ser_open(): can't open device "\\.\COM10": Element not found.
Any explanations?
platformio.ini looks like this (excerpt)
board_build.variant = standard
board_build.mcu = atmega324pa
board_build.f_cpu = 16000000L
monitor_port = COM10
monitor_speed = 57600
upload_port = COM10
upload_speed = 57600
The COM10 serial link is through a HC-06 Bluetooth module, with a simple circuit that mimics the DTR signal to create the processor when the connection is opened
