I have encountered an interesting issue while modifying teensy4 core’s usb device stack. The lower-level calls are all defined in usb.c and only some of them are declared in usb_dev.h while the rest are declared/defined as static.
In my project, I need to access some of these static functions. They are not any part of classes, just plain old C functions. So I defined wrapper functions in usb.c such as this one to gain access to the static functions without changing the static nature:
extern void ep0_xmt(const void *data, uint32_t len, int notify) // Liu 2022-03-23 Added this wrapper function to call it from main.cpp
endpoint0_transmit(data, len, notify);
I think the extern keyword is probably unnecessary. So the static function endpoint0_transmit() now has a non-local wrapper that only I know and will use in main.cpp.
Except that I can’t call them. I added their declarations in main.cpp
extern void ep0_xmt(const void *data, uint32_t len, int notify); // Liu 2022-03-23 Added this wrapper function to call it from main.cpp
So when I build, the function ep0_xmt() is not defined.
I found a workaround though. If I place this declaration in usb_dev.h and include it in main.cpp, it works.
I am guessing, in order to build fast, there may have been some separate linking going on that somehow cuts off the links between the functions in usb.c and a caller in main.cpp. By placing the declaration in usb_dev.h and including it in main, that disconnection is removed and a more complete linking process is done. Is there any other explanation to what I saw? Thanks.
