We want to change to the latests development core of the Teensy project (1.154-beta7) as that has support for a renewed SD and SDfat libary. In this forum I have seen people asking the same question before and one of the answers was to use
This for sure can work but only during compile-time. I am using VisualCode with PIO as an extension inside and the great thing of this combination is that you can inspect code until the libraries from the IDE. But when refering to the 1.154.0-beta7 via the github link thats not the case. In fact I see the “default” 1.153.0 library files.
Anybody that has a guess how to do this in a reliable/proper way ? For the moment I have simply overwritten all core/libraries in the framework-arduinoteensy library with the new libraries. That does work but during compilation the system thinks its version 1.153 still.
The platform versions you are able to reference here are that of platform-teensy (Releases · platformio/platform-teensy · GitHub), as per docs. This is not the version of the Teensy-Arduinocore. That’s a package. The framework-arduinoteensy package. With platform_packages you can “switch out” the source of a package, that’s what my above
instruction does. So if you add that to the platformio.ini (and you have git installed of course), you’ll not be using the standard
version of it but the one contained in the repo, in which I put the 1.54 Beta #7 files.
And that is not working if you add those two lines?
You probably forgot to refresh the IntelliSense with Ctrl+Shift+P → Rebuild IntelliSense. It should take you to the new version of the files, not the old ones, then.
As you can read in my intial question. This only changes the environment at “compile time”, so when I am editing my source and want to see how a library is organized I end up looking at the libraries of 1.153.0 and not those of 1.154.0-beta7. And since some of the libraries have massive changes that is not a safe way of code-development. As stated I am working in VScode with PIO.
thanks for reacting BTW, I had not expected such a fast response.
Ive marked the answer for future reference, the reason that I had not thought this was necessary is because I have the platform-ide: autorebuild setting ON. This states that when platform.ini is changed or new libraries are added intellisense will be rebuild.
Do I miss something ?
Mhm there might be a time delay between changing the platformio.ini, PlatformIO pulling the new core package, after then it should only rebuild, or it didn’t trigger correctly, no idea That’s why I always like to refresh with the keyboard shortcut.
if it is not possible to create a git source, maybe you could guide me to successfully implement manually?
the exit fault with my setup is this (the outputs with warnings is quite long, so i truncated the output to what i think is the problem):
Linking .pio\build\teensy41\firmware.elf
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.startup+0x0): relocation truncated to fit: R_ARM_PREL31 against `.startup'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.startup+0x8): relocation truncated to fit: R_ARM_PREL31 against `.startup'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.startup+0x10): relocation truncated to fit: R_ARM_PREL31 against `.startup'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.flashmem+0x0): relocation truncated to fit: R_ARM_PREL31 against `.flashmem'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.flashmem+0x8): relocation truncated to fit: R_ARM_PREL31 against `.flashmem'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.flashmem+0x10): relocation truncated to fit: R_ARM_PREL31 against `.flashmem'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.flashmem+0x18): relocation truncated to fit: R_ARM_PREL31 against `.flashmem'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.flashmem+0x20): relocation truncated to fit: R_ARM_PREL31 against `.flashmem'
.pio\build\teensy41\libFrameworkArduino.a(startup.c.o):(.ARM.exidx.flashmem+0x28): relocation truncated to fit: R_ARM_PREL31 against `.flashmem'
.pio\build\teensy41\libFrameworkArduino.a(analog.c.o):(.ARM.exidx.flashmem+0x0): relocation truncated to fit: R_ARM_PREL31 against `.flashmem'
.pio\build\teensy41\libFrameworkArduino.a(tempmon.c.o):(.ARM.exidx.flashmem+0x0): additional relocation overflows omitted from the output
*** [.pio\build\teensy41\firmware.elf] Error 1
============================================================= [FAILED] Took 54.29 seconds =============================================================
* Der Terminalprozess "C:\Users\Admin\.platformio\penv\Scripts\platformio.exe 'run'" wurde mit folgendem Exitcode beendet: 1.
* Das Terminal wird von Aufgaben wiederverwendet, drücken Sie zum Schließen eine beliebige Taste.
to get the up2date version of teensy which is 1.57 right now, but i need to use 1.58beta2. this version is not in the official platformio git-repo, therefore its imho not possible to do like you suggested.
actually it must be the same issue when you had to implement 1.54beta7 isn’t it? @maxgerhardt provided a source on github with the implementation of 1.54beta7 for you… am i wrong?
The reason why I just changed to using platform = teensy@4.13.0 is that it gives me full control over the version of teensyduino I am using (or testing). When I distribute code to others that might have another teensyduino environment this comes in rather handy. But its not going to help you out as it only links to stable releases.
