Hello
I get errors during build when I use std::vector, for example:
std::vector a {1,2,3,4};
Here is the log:
[10/03/16 11:23:49] Processing teensy31 (platform: teensy, board: teensy31, framework: arduino)
Verbose mode can be enabled via -v, --verbose
option
Collected 87 compatible libraries
Looking for dependencies…
Library Dependency Graph
| |-- v1.0.8
| | |-- v1.0
| |-- v1.3
| | |-- v1.0.8
| | | |-- v1.0
| | |-- v1.0
| | |-- v0.4
| | | |-- v1.0
| | |-- v1.0
| |-- v1.0
| |-- v1.0
Compiling .pioenvs\teensy31\lib\Synth\SynthLib.o
Archiving .pioenvs\teensy31\lib\libSynth.a
Linking .pioenvs\teensy31\firmware.elf
c:/users/komal/.platformio/packages/toolchain-gccarmnoneeabi/bin/…/lib/gcc/arm-none-eabi/4.8.4/…/…/…/…/arm-none-eabi/lib/armv7e-m\libc_s.a(lib_a-signalr.o): In function _kill_r': signalr.c:(.text._kill_r+0xe): undefined reference to
_kill’
c:/users/komal/.platformio/packages/toolchain-gccarmnoneeabi/bin/…/lib/gcc/arm-none-eabi/4.8.4/…/…/…/…/arm-none-eabi/lib/armv7e-m\libc_s.a(lib_a-signalr.o): In function _getpid_r': signalr.c:(.text._getpid_r+0x0): undefined reference to
_getpid’
*** [.pioenvs\teensy31\firmware.elf] Error 1
[ERROR] Took 5.13 seconds
If I remove the std::vector type variables the build is successful, I would like to use vectors so that I could use binary_search functions in CPP algorithms library.
