Well the base error is that PlatformIO doesn’t seem to be able to execute any commands from inside VSCode to the Jlink tools.
When I do “Start Debugging” in VSCode with the above platformio.ini
, I do get the JLink output, telling me it failed to start (since no JLink is connected of course)
And I do get the “Verbose Upload” JLink output as indicated above.
I’m not excluding antivirus to be a culprit if you get no output at all.
It seems to help in your setup though to specify explicit commands.
For uploading you can also try the platformio.ini
[env:teensy41]
platform = teensy
board = teensy41
upload_protocol = custom
upload_command =
$PROJECT_PACKAGES_DIR/tool-jlink/JLink.exe
-device
MIMXRT1062xxxxA
-if
jtag
-autoconnect
1
-NoGui
1
-CommanderScript
upload.jlink
And a upload.jlink
file at the same level as the platformio.ini
with content
h
loadfile .pio\build\teensy41\firmware.hex
r
q
Then check “Verbose Upload” if the tool is invoked correctly and flashes correctly (docs).
