Hello! Here is the error I get:
/home/pi/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: cannot find -larm_cortexM7lfsp_math
*** [.pio/build/teensy40/firmware.elf] Error 1
You need to recopy the missing libraries per Teensy 4.0 not compiling on Raspberry pi, bits/c++config.h: No such file or directory - #7 by maxgerhardt to the /home/pi/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/lib again.
I have this new error? Thanks again
Processing teensy40 (platform: teensy; framework: arduino; board: teensy40)
Tool Manager: Installing https://github.com/maxgerhardt/pio-tool-teensy-arm/arc hive/master.zip
Tool Manager: tool-teensy @ 1.152.200516 has been installed!
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy40.html
PLATFORM: Teensy (4.11.0) > Teensy 4.0
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 1.94MB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy 1.153.0 (1.53)
- toolchain-gccarmnoneeabi 1.90301.200702 (9.3.1)
Found 91 compatible libraries
|-- <OctoWS2811> 1.4.0+sha.aa374fc
|-- <SPI> 1.0
|-- <arduinoFFT> 1.5.5
Linking .pio/build/teensy40/firmware.elf
Building .pio/build/teensy40/firmware.hex
Checking size .pio/build/teensy40/firmware.elf
RAM: [== ] 20.5% (used 107220 bytes from 524288 bytes)
Flash: [ ] 3.0% (used 60480 bytes from 2031616 bytes)
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-cli
Rebooting...
sh: 1: teensy_reboot: not found
*** [upload] Error 127
========================= [FAILED] Took 3.69 seconds =========================
Hm seems can’t find the teensy_reboot binary. Also the used packages shown
don’t include the explicit override for tool-teensy. Is that line still in the platformio.ini?
If yes, I’ll have to reproduce this on my Pi and check what’s up.
When I removed the line for
tool-teensy
I get this error:
Unknown MCU type "imxrt1062"
Supported MCUs are:
- at90usb162
- atmega32u4
- at90usb646
- at90usb1286
- mkl26z64
- mk20dx128
- mk20dx256
- mk66fx1m0
- mk64fx512
- TEENSY2
- TEENSY2PP
- TEENSYLC
- TEENSY30
- TEENSY31
- TEENSY35
- TEENSY36
Interesting, so it either takes the old package version or does not accept the new package via the override.
Are you 100% certain the formatting in the platformio.ini is correct? There must be at least 3 spaces before the tool-teensy line.
You can also try to rm -rf ~/.platformio/packages/tool-teensy* your old packages to force a redownload.
Got rid of the ini and copied it exactly from your post, this is what I got again:
pi@raspberrypi:~/Documents/Visualisd $ pio run --target upload
Tool Manager: Installing https://github.com/maxgerhardt/pio-tool-teensy-arm/archive/master.zip
|-- <SPI> 1.0
Rebooting...
====================================================================== [FAILED] Took 3.67 seconds ==============================================```
I also did
Yeah the error is reproducable for me on the latest PlatformIO version (latest dev 5.0.2b2) but not the version I was on before that… I’ll see if if I can fix this with advanced scripting or uploading to the trusted PlatformIO package repository.
Guaranteed fixed by pip uninstall platformio and pip install 'platformio==4.3.4 and then /home/pi/.local/bin/pio run in the project, but ugly.
Gotcha thanks. Let me know if you end up finding another solution
I’ve correct the package.json in Update package.json · maxgerhardt/pio-tool-teensy-arm@83d4e72 · GitHub and now it works for me.
With the same platformio.ini as posted above, execute
rm -rf ~/.platformio/.cache/*
pio run -t upload
in the project.
for me that outputs at the start
pi@raspberrypi:~/arduino-blink $ pio run
Downloading...
- tool-teensy 1.152.200516 (1.52)
and the package is found.
If that is not the case, try pio upgrade --dev so that you have the same version as me.
Hey! that worked great! Thanks!
Today, I also got this problem:
In file included from /home/pi/.platformio/packages/framework-arduinoteensy/cores/teensy4/wiring.h:45:0,
from /home/pi/.platformio/packages/framework-arduinoteensy/cores/teensy4/WProgram.h:45,
from /home/pi/.platformio/packages/framework-arduinoteensy/cores/teensy4/Arduino.h:6,
from src/prog.cpp:1:
/home/pi/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/5.4.1/type_traits:38:28: fatal error: bits/c++config.h: No such file or directory
compilation terminated.
*** [.pio/build/teensy40/src/prog.cpp.o] Error 1
Is there a more recent new solution than the one from Oct 2020?
I am using:
[env:teensy40]
platform = teensy
board = teensy40
On a raspberry pi zero w
the teensy36 seems to compile well with
[env:teensy36]
platform = teensy
board = teensy36
Have you tried it with the options referenced in the issue?
[env:teensy40]
platform = teensy
board = teensy40
platform_packages =
toolchain-gccarmnoneeabi@~1.90301.0
tool-teensy@https://github.com/maxgerhardt/pio-tool-teensy-arm/archive/master.zip
plus adding the library file per Teensy 4.0 not compiling on Raspberry pi, bits/c++config.h: No such file or directory - #7 by maxgerhardt? (path might to toolchain might slightly differ)
