I’ve been running for a while, working okay,
Then this happens …
Whats wrong, I did not touch anything
Processing esp-wrover-kit (framework: arduino; platform: espressif32; board: esp-wrover-kit)
LibraryManager: Installing webthing-arduino
git version 2.20.1.windows.1
Cloning into 'c:\Users\Lars-Göran Lindström\Documents\PlatformIO\Projects\thingsExampleESP21\.piolibdeps\_tmp_installing-dk8cpn-package'...
remote: Enumerating objects: 44, done.
remote: Counting objects: 100% (44/44), done.
remote: Compressing objects: 100% (34/34), done.
remote: Total 44 (delta 5), reused 23 (delta 1), pack-reused 0
Unpacking objects: 100% (44/44), done.
LibraryManager: Installing id=64
File "c:\.platformio\penv\lib\site-packages\platformio\__main__.py", line 120, in main
cli(None, None, None)
File "c:\.platformio\penv\lib\site-packages\click\core.py", line 700, in __call__
File "c:\.platformio\penv\lib\site-packages\click\core.py", line 680, in main
rv = self.invoke(ctx)
File "c:\.platformio\penv\lib\site-packages\click\core.py", line 1027, in invoke
File "c:\.platformio\penv\lib\site-packages\click\core.py", line 873, in invoke
File "c:\.platformio\penv\lib\site-packages\click\core.py", line 508, in invoke
return callback(*args, **kwargs)
File "c:\.platformio\penv\lib\site-packages\click\decorators.py", line 16, in new_func
File "c:\.platformio\penv\lib\site-packages\platformio\commands\run.py", line 107, in cli
result = (envname, ep.process())
File "c:\.platformio\penv\lib\site-packages\platformio\commands\run.py", line 207, in process
result = self._run()
File "c:\.platformio\penv\lib\site-packages\platformio\commands\run.py", line 302, in _run
self.verbose)
File "c:\.platformio\penv\lib\site-packages\platformio\commands\run.py", line 325, in _autoinstall_libdeps
ctx.invoke(cmd_lib_install, libraries=[lib], silent=not verbose)
File "c:\.platformio\penv\lib\site-packages\click\decorators.py", line 26, in new_func
return f(get_current_context().obj, *args, **kwargs)
File "c:\.platformio\penv\lib\site-packages\platformio\commands\lib.py", line 103, in lib_install
library, silent=silent, interactive=interactive, force=force)
File "c:\.platformio\penv\lib\site-packages\platformio\managers\lib.py", line 352, in install
force=force)
File "c:\.platformio\penv\lib\site-packages\platformio\managers\package.py", line 723, in install
pkg_dir = self._install_from_piorepo(name, requirements)
File "c:\.platformio\penv\lib\site-packages\platformio\managers\lib.py", line 213, in _install_from_piorepo
if app.get_setting("enable_ssl") else dl_data['url'], requirements)
File "c:\.platformio\penv\lib\site-packages\platformio\managers\package.py", line 508, in _install_from_url
dlpath = self.download(url, tmp_dir, sha1)
File "c:\.platformio\penv\lib\site-packages\platformio\managers\package.py", line 178, in download
dst_path = join(dest_dir, fname)
File "c:\.platformio\penv\lib\ntpath.py", line 85, in join
result_path = result_path + p_path
UnicodeDecodeError: 'ascii' codec can't decode byte 0xf6 in position 13: ordinal not in range(128)
`pip install -U platformio` command
https://docs.platformio.org/page/faq.html
