Could you try this solution?
I have the same issue.
vcode version 1.19 x64
Home 0.5.3 ·Core 3.5.0rc9
os: win10 x64
I tried Atom, the “open directory” still not working
- Close IDE
- Please navigate to Windows Control Panel > Applications, uninstall ALL Pythons from a system
- Remove
%HOME_DIR%/.platformiofolder - Start IDE.
Should work now.
I had this problem but in the atom editor with platformIO package. Home screen works but not the projects view.
Deleting the .platformio folder helps, but the problem returned when i added the projects again.
Same with uninstalling all pythons.
My Solution was to delete the “description” fields inside the platformio.ini files
