libTest.h
// put function declarations here:
extern int myFunction(int, int);
libTest.cpp
// put function definitions here:
int myFunction(int x, int y) {
return x + y;
main.cpp
#include "main.h"
#include "libTest.h"
int result = myFunction(2, 3);
Build Log:
Executing task: C:\Users\rosen\.platformio\penv\Scripts\platformio.exe run
--------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (6.9.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20017.241212+sha.dcc1105b
Found 35 compatible libraries
Compiling .pio\build\esp32dev\src\main.cpp.o
Building .pio\build\esp32dev\bootloader.bin
Generating partitions .pio\build\esp32dev\partitions.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
src/main.cpp:2:10: fatal error: libTest.h: No such file or directory
* Looking for libTest.h dependency? Check our library registry!
* CLI > platformio lib search "header:libTest.h"
* Web > https://registry.platformio.org/search?q=header:libTest.h
compilation terminated.
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
================================== [FAILED] Took 12.68 seconds ==================================
* The terminal process "C:\Users\rosen\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
If I move the files into the “include” and “src” folders from the “libs” then it compiles correctly.
First part of the c_cpp_properties.json has the “include” and “src” but not the “libs”.
"configurations": [
"name": "PlatformIO",
"includePath": [
"c:/Platformio/Project/IssueTest/include",
"c:/Platformio/Project/IssueTest/src",
"C:/Users/rosen/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/newlib/platform_include",
"C:/Users/rosen/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/freertos/include",
"C:/Users/rosen/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/freertos/include/esp_additions/freertos",
