Hey guy! Happy Christmas to all of you!
I’m working on this project, but it stopped compiling. And I’m getting strange errors.
this is the compile output:
> Executing task: platformio run <
Processing d1_mini (platform: espressif8266; board: d1_mini; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 (3.2.0) > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.30002.0 (3.0.2)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa 2.100300.210717 (10.3.0)
Found 51 compatible libraries
|-- <DoubleResetDetector> 1.0.2
|-- <ArduinoJson> 5.13.2
|-- <LinkedList> 0.0.0-alpha+sha.dac3874d28
|-- <WebSockets> 2.1.2
| |-- <ESP8266WiFi> 1.0
| | |-- <Updater>
| | | |-- <LedHandler>
| | | | |-- <Adafruit NeoPixel> 1.10.3
| | | |-- <ESP8266httpUpdate> 1.3
| | | | |-- <ESP8266HTTPClient> 1.2
| |-- <ESPAsyncTCP> 1.2.2+sha.1547686
| |-- <Ethernet> 2.0.0
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Hash> 1.0
|-- <SocketIoClient> 0.3.0
| | | |-- <Updater>
| | | | |-- <LedHandler>
| | |-- <Ethernet> 2.0.0
| | | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| | |-- <Hash> 1.0
|-- <WiFiManager> 0.15.0
| |-- <DNSServer> 1.1.1
| | | |-- <Updater>
| | | | |-- <LedHandler>
| |-- <ESP8266WebServer> 1.0
| | | |-- <Updater>
| | | | |-- <LedHandler>
| | |-- <Updater>
| | | |-- <LedHandler>
|-- <LedHandler>
|-- <Modules>
| |-- <Wire> 1.0
|-- <Socket>
| |-- <LedHandler>
| | |-- <Updater>
| | | |-- <LedHandler>
| | | | |-- <Updater>
| | | | | |-- <LedHandler>
| | | |-- <Ethernet> 2.0.0
| | | | |-- <SPI> 1.0
| | | |-- <SPI> 1.0
| | | |-- <Hash> 1.0
| | | | |-- <Updater>
| | | | | |-- <LedHandler>
| | | | |-- <Updater>
| | | | | |-- <LedHandler>
| | | |-- <Updater>
| | | | |-- <LedHandler>
|-- <StepperMotor>
| |-- <AccelStepper>
|-- <Updater>
| |-- <LedHandler>
|-- <LittleFS> 0.1.0
Compiling .pio/build/d1_mini/lib384/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling .pio/build/d1_mini/lib384/ESP8266WiFi/CertStoreBearSSL.cpp.o
Compiling .pio/build/d1_mini/lib6cb/WebSockets/WebSocketsClient.cpp.o
Archiving .pio/build/d1_mini/lib02c/libSocket.a
Indexing .pio/build/d1_mini/lib02c/libSocket.a
Archiving .pio/build/d1_mini/libbe9/libAccelStepper.a
Indexing .pio/build/d1_mini/libbe9/libAccelStepper.a
Archiving .pio/build/d1_mini/libc06/libLittleFS.a
Indexing .pio/build/d1_mini/libc06/libLittleFS.a
Compiling .pio/build/d1_mini/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/LwipDhcpServer.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/LwipIntf.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/LwipIntfCB.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/Print.cpp.o
In file included from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:30,
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecure.h:23,
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiServerSecure.h:20,
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/ESP8266WiFi.h:41,
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266httpUpdate/src/ESP8266httpUpdate.h:30,
from lib/Updater/Updater.h:5,
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/BearSSLHelpers.h:28,
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/BearSSLHelpers.cpp:23:
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/CertStoreBearSSL.h:57:5: error: 'X509List' does not name a type
57 | X509List *_x509 = nullptr;
In file included from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecure.h:23,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:37:31: error: 'WiFiClientSecure' does not name a type; did you mean 'WiFiClientSecureCtx'?
37 | WiFiClientSecureCtx(const WiFiClientSecure &rhs) = delete;
| ^~~~~~~~~~~~Compiling .pio/build/d1_mini/FrameworkArduino/Schedule.cpp.o
| WiFiClientSecureCtx
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:64:21: error: 'Session' has not been declared
64 | void setSession(Session *session) { _session = session; }
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:72:28: error: 'PublicKey' does not name a type
72 | void setKnownKey(const PublicKey *pk, unsigned usages = BR_KEYTYPE_KEYX | BR_KEYTYPE_SIGN) {
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:91:32: error: 'X509List' does not name a type
91 | void setTrustAnchors(const X509List *ta) {
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:100:33: error: 'X509List' does not name a type
100 | void setClientRSACert(const X509List *cert, const PrivateKey *sk);
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:100:55: error: 'PrivateKey' does not name a type
Compiling .pio/build/d1_mini/FrameworkArduino/StackThunk.cpp.o
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:101:32: error: 'X509List' does not name a type
101 | void setClientECCert(const X509List *cert, const PrivateKey *sk,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:101:54: error: 'PrivateKey' does not name a type
Compiling .pio/build/d1_mini/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/d1_mini/FrameworkArduino/StreamSend.cpp.o
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:162:11: error: 'X509List' does not name a type
162 | const X509List *_ta;
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/CertStoreBearSSL.h:24,
from /home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/CertStoreBearSSL.cpp:20:
| WiFiClientSecureCtx
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:171:5: error: 'Session' does not name a type
171 | Session *_session;
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:177:11: error: 'PublicKey' does not name a type
177 | const PublicKey *_knownkey;
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:199:11: error: 'X509List' does not name a type
199 | const X509List *_chain;
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:200:11: error: 'PrivateKey' does not name a type
200 | const PrivateKey *_sk;
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:206:54: error: 'X509List' does not name a type
206 | WiFiClientSecureCtx(ClientContext *client, const X509List *chain, unsigned cert_issuer_key_type,
Compiling .pio/build/d1_mini/FrameworkArduino/Tone.cpp.o
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:211:29: error: 'X509List' does not name a type
211 | const X509List *client_CA_ta, int tls_min, int tls_max);
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:214:37: error: 'X509List' does not name a type
214 | bool _connectSSLServerRSA(const X509List *chain, const PrivateKey *sk,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:214:60: error: 'PrivateKey' does not name a type
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:215:31: error: 'ServerSessions' has not been declared
215 | ServerSessions *cache, const X509List *client_CA_ta);
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:215:60: error: 'X509List' does not name a type
Compiling .pio/build/d1_mini/FrameworkArduino/TypeConversion.cpp.o
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:217:36: error: 'X509List' does not name a type
217 | bool _connectSSLServerEC(const X509List *chain, unsigned cert_issuer_key_type, const PrivateKey *sk,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:288:54: error: 'PrivateKey' does not name a type
288 | void setClientECCert(const X509List *cert, const PrivateKey *sk,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:217:90: error: 'PrivateKey' does not name a type
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:218:30: error: 'ServerSessions' has not been declared
218 | ServerSessions *cache, const X509List *client_CA_ta);
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:218:59: error: 'X509List' does not name a type
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:222:44: error: 'X509List' does not name a type
222 | bool _installServerX509Validator(const X509List *client_CA_ta); // Setup X509 client cert validation, if supplied
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h: In member function 'void BearSSL::WiFiClientSecureCtx::setSession(int*)':
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:64:41: error: '_session' was not declared in this scope; did you mean 'session'?
| session
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:338:51: error: 'X509List' does not name a type
338 | WiFiClientSecure(ClientContext *client, const X509List *chain, unsigned cert_issuer_key_type,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:339:29: error: 'PrivateKey' does not name a type
339 | const PrivateKey *sk, int iobuf_in_size, int iobuf_out_size, ServerSessions *cache,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:339:84: error: 'ServerSessions' has not been declared
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h: In member function 'void BearSSL::WiFiClientSecureCtx::setKnownKey(const int*, unsigned int)':
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:74:7: error: '_knownkey' was not declared in this scope
74 | _knownkey = pk;
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h: In member function 'void BearSSL::WiFiClientSecureCtx::setTrustAnchors(const int*)':
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:93:7: error: '_ta' was not declared in this scope; did you mean 'ta'?
93 | _ta = ta;
| ta
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:340:29: error: 'X509List' does not name a type
340 | const X509List *client_CA_ta, int tls_min, int tls_max):
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h: In member function 'void BearSSL::WiFiClientSecureCtx::setCertStore(int*)':
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:117:7: error: '_certStore' was not declared in this scope; did you mean 'certStore'?
117 | _certStore = certStore;
| certStore
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h: At global scope:
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:265:21: error: 'Session' has not been declared
265 | void setSession(Session *session) { _ctx->setSession(session); }
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:344:51: error: 'X509List' does not name a type
344 | WiFiClientSecure(ClientContext* client, const X509List *chain, const PrivateKey *sk,
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClientSecureBearSSL.h:271:28: error: 'PublicKey' does not name a type
271 | void setKnownKey(const PublicKey *pk, unsigned usages = BR_KEYTYPE_KEYX | BR_KEYTYPE_SIGN) {
.pio/libdeps/d1_mini/WebSockets/src/WebSocketsClient.cpp: In member function 'void WebSocketsClient::connectedCb()':
.pio/libdeps/d1_mini/WebSockets/src/WebSocketsClient.cpp:704:26: error: 'class BearSSL::WiFiClientSecure' has no member named 'verify'
704 | if(!_client.ssl->verify(_fingerprint.c_str(), _host.c_str())) {
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.h:81:5: error: 'ServerSessions' does not name a type
81 | ServerSessions *_cache = nullptr;
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.h: In member function 'void BearSSL::WiFiServerSecure::setCache(int*)':
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.h:47:7: error: '_cache' was not declared in this scope; did you mean 'cache'?
47 | _cache = cache;
| cache
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.h: In member function 'void BearSSL::WiFiServerSecure::setClientTrustAnchor(const int*)':
/home/stefan/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiServerSecureBearSSL.h:60:7: error: '_client_CA_ta' was not declared in this scope; did you mean 'client_CA_ta'?
60 | _client_CA_ta = client_CA_ta;
| client_CA_ta
Compiling .pio/build/d1_mini/FrameworkArduino/abi.cpp.o
*** [.pio/build/d1_mini/lib6cb/WebSockets/WebSocketsClient.cpp.o] Error 1
*** [.pio/build/d1_mini/lib384/ESP8266WiFi/CertStoreBearSSL.cpp.o] Error 1
*** [.pio/build/d1_mini/lib384/ESP8266WiFi/BearSSLHelpers.cpp.o] Error 1
============================================= [FAILED] Took 2.60 seconds =============================================
The terminal process "platformio 'run'" terminated with exit code: 1.
I have really no idea where to look because it looks like the errors come out of a Lib that is downloaded by platformio.
Somebody here that could help me out.
