Dear Chinese friends sold to me a strange ‘bluepill’ which has STM32F103CBT6 MCU, that cannot be started with:
- generic_stm32f103xx
- maple_mini_b20
… etc
That ‘bluepill’ program well via STLink utility and STLink USB dongle, I can write memory, erase memory, read memory, etc.
But:
General sketch, such as blink, not working at all.
Uploading .pioenvs\genericSTM32F103C8\firmware.elf
GNU MCU Eclipse 64-bit Open On-Chip Debugger 0.10.0+dev-00462-gdd1d90111 (2019-01-18-11:42)
Licensed under GNU GPL v2
For bug reports, read
hla_swd
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
Info : clock speed 1000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : STLINK V2J33S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.229005
Info : stm32f1x.cpu: hardware has 6 breakpoints, 4 watchpoints
xPSR: 0x01000000 pc: 0x08000380 msp: 0x20005000
** Programming Started **
auto erase enabled
Info : device id = 0x20036410
Info : flash size = 128kbytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x2000003a msp: 0x20005000
wrote 40960 bytes from file .pioenvs\genericSTM32F103C8\firmware.elf in 2.313600s (17.289 KiB/s)
** Programming Finished **
** Verify Started **
xPSR: 0x61000000 pc: 0x2000002e msp: 0x20005000
verified 40104 bytes in 0.674437s (58.069 KiB/s)
** Verified OK **
** Resetting Target **
shutdown command invoked
and then, no LED flashes.
What can I do with this ‘invalid’ MCU?
That is general code:
delay(20);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
delay(250);
