I’m working on uploading the MPU6050_tockn
library example to my STM32F103C8 Blue Pill board.
Processing genericSTM32F103C8 (platform: ststm32; board: genericSTM32F103C8; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103C8.html
PLATFORM: ST STM32 > STM32F103C8 (20k RAM. 64k Flash)
HARDWARE: STM32F103C8T6 72MHz 20KB RAM (64KB Flash)
DEBUG: CURRENT(blackmagic) EXTERNAL(blackmagic, jlink, stlink)
Collected 33 compatible libraries
|-- <Wire> 1.0
|-- <MPU6050_tockn> 1.4.0
| |-- <Wire> 1.0
Compiling .pioenvs\genericSTM32F103C8\src\main.cpp.o
Archiving .pioenvs\genericSTM32F103C8\lib017\libWire.a
Compiling .pioenvs\genericSTM32F103C8\lib0d0\MPU6050_tockn_ID2824\MPU6050_tockn.cpp.o
Indexing .pioenvs\genericSTM32F103C8\lib017\libWire.a
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp: In member function 'void MPU6050::calcGyroOffsets(bool)':
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp:71:53: error: no matching function for call to 'TwoWire::requestFrom(int, int, int)'
wire->requestFrom((int)MPU6050_ADDR, 14, (int)true);
In file included from C:\Users\neilb\.platformio\packages\framework-arduinoststm32-maple\STM32F1\libraries\Wire/Wire.h:42:0,
from C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.h:5,
from C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp:1:
C:\Users\neilb\.platformio\packages\framework-arduinoststm32-maple\STM32F1\libraries\Wire/utility/WireBase.h:101:11: note: candidate: uint8 WireBase::requestFrom(uint8, int)
uint8 requestFrom(uint8, int);
C:\Users\neilb\.platformio\packages\framework-arduinoststm32-maple\STM32F1\libraries\Wire/utility/WireBase.h:101:11: note: candidate expects 2 arguments, 3 provided
C:\Users\neilb\.platformio\packages\framework-arduinoststm32-maple\STM32F1\libraries\Wire/utility/WireBase.h:106:11: note: candidate: uint8 WireBase::requestFrom(int, int)
uint8 requestFrom(int, int);
C:\Users\neilb\.platformio\packages\framework-arduinoststm32-maple\STM32F1\libraries\Wire/utility/WireBase.h:106:11: note: candidate expects 2 arguments, 3 provided
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp:73:21: warning: value computed is not used [-Wunused-value]
wire->read() << 8 | wire->read();
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp:74:21: warning: value computed is not used [-Wunused-value]
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp:75:21: warning: value computed is not used [-Wunused-value]
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp:76:21: warning: value computed is not used [-Wunused-value]
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp: In member function 'void MPU6050::update()':
C:\Users\neilb\.platformio\lib\MPU6050_tockn_ID2824\src\MPU6050_tockn.cpp:105:52: error: no matching function for call to 'TwoWire::requestFrom(int, int, int)'
*** [.pioenvs\genericSTM32F103C8\lib0d0\MPU6050_tockn_ID2824\MPU6050_tockn.cpp.o] Error 1
When I look at this, I think the main problem is here:
But this doesn’t make sense, because when I look at the API calls made and offered by the respective files, both call upon/offer the same exact fingerprint. Something isn’t right, but I’m not able to figure it out.
The same exact example builds perfectly for an AVR plarform like the Uno or Pro Micro.
Any thoughts? Thanks!
