STM32-E407 doesn’t work on PIO
Now it works on USB-OTG#1. I added your SystemClock_Config() in my project and it works. Some things remain though:
  • I don’t know the syntax of the extern "C" stuff so I did not use it and it works like that.
  • I put the function directly in a .h file without .c file as I didn’t find a way to make it work.
  • The serial connection is completely dropped when the board is reseted i.e. I need to relaunch the terminal each time I reset the board. This is not the case with Serial 3 and 6.
I pushed the code to my depot on GitHub if you want to have a look.
