logs in github - build.log and arduino_build.log
You still have build_type = debug
in the platformio.ini
causing a debug build, please use the platformio.ini
from above
Another cause might be that PlatformIO is using
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
While the Arduino IDE uses
tools\\xpack-arm-none-eabi-gcc\\10.3.1-2.3/bin/arm-none-eabi-g++"
Please add
platform_packages =
toolchain-gccarmnoneeabi@~1.100301.0
and retry if that helps + reupload log for PlatformIO.
I discovered that earlier. Your suggested minimal config doesnāt build. This is what Iāve got which generates a working release build. A debug build is still broken. Iāll upload the build log in a minute.
[env:electrosmith_daisy]
platform = ststm32
board = electrosmith_daisy
Wire
adafruit/Adafruit ILI9341@^1.5.7
adafruit/Adafruit BusIO@^1.8.2
adafruit/Adafruit seesaw Library@^1.6.1
build_flags = -w
-D HAL_SDRAM_MODULE_ENABLED
-D HAL_MDMA_MODULE_ENABLED
-D HAL_DMA_MODULE_ENABLED
-D INSTRUCTION_CACHE_ENABLE
-D USBD_USE_CDC
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
debug_tool = stlink
platform_packages =
platformio/toolchain-gccarmnoneeabi@^1.100301.220327
Incidentally I found that all the files like .platformio/platforms/stm32/boards/electrosmith_daisy.json have the flash and ram sizes swapped. I.e. they read
"name": "Electrosmith Daisy",
"upload": {
"maximum_ram_size": 131072,
"maximum_size": 524288,
where they should read
"upload": {
"maximum_ram_size": 524288,
"maximum_size": 131072,
Apologies if my replies are a little short. I have a broken arm so trying to type as little as possible.
Thatās definitely a bug one can report.
But then besides the debug optimization flags (which should be gone by now) I notice that the PlatformIO variant seems to hvae the USB CDC flags enabled while in the Arduino build it is not. Do you use the USB in the Arduino IDE example?
Otherwise I would suggest to take a small step back and use the Dhrystone benchmark code in the Arduino IDE and in PlatformIO and compare the numbers. If theyāre significantly different thereās something wrong in the CPU optimization flags. Whetstone can also be done (checks floating point unit performance)
Iāve tried with and without USB CDC - makes no difference. If I could get the debugger to work I wouldnāt need it
Iāll see what Dhrystone tells me. Itās got to be be a clock config or optimization flag but I just canāt see it.
And the results are⦠no significant difference in speed between debug and release build and build in the Arduino IDE (all about 1M Dhrystones)
The sketch needed some tweaking to work - include Arduino.h and then add the USB/CDC definitions to platformio.ini
And what about Whetstone?
100% The same library versions used?
Solution!
debug_build_flags =
-Os -ggdb2 -g2
Thanks so much for your help Max!
Where should I report the issues in the boards files?
But that just gets used when build_type = debug
or when you start debugging ā was the regular release build working all the time?
That goes to Issues Ā· platformio/platform-ststm32 Ā· GitHub
Thanks again! Iāll post there.
