Still refusing libraries, but now this
It’s 4pm. I’ve spent half the day trying to get Adafruit_I2CDevice.h to be recognized. I just pasted a link into .ini, and now this:
Executing task in folder BLE_BME_680_WeMos: C:\Users\joema.platformio\penv\Scripts\platformio.exe run <
Processing wemos_d1_mini32 (platform: espressif32; board: wemos_d1_mini32; framework: arduino)
CONFIGURATION: Redirecting...
PLATFORM: Espressif 32 1.12.4 > WeMos D1 MINI ESP32
  • framework-arduinoespressif32 3.10004.200129 (1.0.4)
  • tool-esptoolpy 1.20600.0 (2.6.0)
  • toolchain-xtensa32 2.50200.80 (5.2.0)
    LibraryManager: Installing Adafruit_I2CDevice
    git version 2.21.0.windows.1
    Cloning into ‘C:\Users\joema\Documents\PlatformIO\Projects\BLE_BME_680_WeMos.pio\libdeps\wemos_d1_mini32_tmp_installing-yw5m6bpr-package’…
    fatal: repository ‘Adafruit_BusIO/Adafruit_I2CDevice.h at master · adafruit/Adafruit_BusIO · GitHub’ not found
    PlatformioException: VCS: Could not process command [‘git’, ‘clone’, ‘–recursive’, ‘–depth’, ‘1’, ‘Adafruit_BusIO/Adafruit_I2CDevice.h at master · adafruit/Adafruit_BusIO · GitHub’, ‘C:\Users\joema\Documents\PlatformIO\Projects\BLE_BME_680_WeMos\.pio\libdeps\wemos_d1_mini32\_tmp_installing-yw5m6bpr-package’]:
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\builder\main.py”, line 168:
    env.SConscript(“$BUILD_SCRIPT”)
    File “C:\Users\joema.platformio\packages\tool-scons\script..\engine\SCons\Script\SConscript.py”, line 597:
    File “C:\Users\joema.platformio\packages\tool-scons\script..\engine\SCons\Script\SConscript.py”, line 286:
    exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals)
    File “C:\Users\joema.platformio\platforms\espressif32\builder\main.py”, line 223:
    File “C:\Users\joema.platformio\packages\tool-scons\script..\engine\SCons\Environment.py”, line 219:
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py”, line 62:
    env.ProcessProjectDeps()
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py”, line 131:
    project_lib_builder = env.ConfigureProjectLibBuilder()
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 1036:
    project.install_dependencies()
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\builder\tools\piolib.py”, line 868:
    lm.install(uri)
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\managers\lib.py”, line 281:
    force=force,
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\managers\package.py”, line 702:
    pkg_dir = self._install_from_url(name, url, requirements, track=True)
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\managers\package.py”, line 486:
    assert vcs.export()
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\vcsclient.py”, line 165:
    assert self.run_cmd(args)
    File “C:\Users\joema.platformio\penv\lib\site-packages\platformio\vcsclient.py”, line 104:
    raise PlatformioException(“VCS: Could not process command %s” % e.cmd)
    ==================================================================================================== [FAILED]
I see at the end it was unable to process a command. But that looks like a lot of yellow text. And it still doesn’t compile.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <Adafruit_GFX.h> //Libraries for the OLED and BMP280
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeSerif9pt7b.h>
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_SSD1306 display(128, 64, &Wire, 8); //Declaring the display name (display)
Adafruit_BME680 bme;                         // I2C
//Adafruit_BME680 bme(BME_CS); // hardware SPI
//Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
void setup()
  Serial.begin(9600);
  bme.begin();
  while (!Serial)
  Serial.println(F("BME680 async test"));
  if (!bme.begin())
    Serial.println(F("Could not find a valid BME680 sensor, check wiring!"));
    while (1)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //Start the OLED display
  display.clearDisplay();
  display.display();
  display.setTextColor(WHITE);
  display.setTextSize(1);
  display.print("SurtrTech"); //Show the name, you can remove it or replace it
  display.setCursor(32, 12);
  display.setTextSize(2);
  display.println("Monster");
  display.setCursor(32, 28);
  display.println("Labs");
  display.display();
  delay(5000);
void loop()
  BLEDevice::init("Monster Laboratories");
  BLEServer *pServer = BLEDevice::createServer();
  BLEService *pService = pServer->createService(SERVICE_UUID);
  BLECharacteristic *pCharacteristic = pService->createCharacteristic(
      CHARACTERISTIC_UUID,
      BLECharacteristic::PROPERTY_READ |
          BLECharacteristic::PROPERTY_WRITE);
 // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  Serial.begin(9600);
  Serial.println("Starting BLE work!");
  // Tell BME680 to begin measurement.
  unsigned long endTime = bme.beginReading();
  if (endTime == 0)
    Serial.println(F("Failed to begin reading :("));
    return;
  Serial.print(F("Reading started at "));
  Serial.print(millis());
  Serial.print(F(" and will finish at "));
  Serial.println(endTime);
  // Obtain measurement results from BME680. Note that this operation isn't
  // instantaneous even if milli() >= endTime due to I2C/SPI latency.
  if (!bme.endReading())
    Serial.println(F("Failed to complete reading :("));
    return;
  Serial.print(F("Reading completed at "));
  Serial.println(millis());
  pCharacteristic->setValue(bme.temperature);
  pService->start();
  // BLEAdvertising *pAdvertising = pServer->getAdvertising();  // this still is working for backward compatibility
  BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
  pAdvertising->addServiceUUID(SERVICE_UUID);
  pAdvertising->setScanResponse(true);
  pAdvertising->setMinPreferred(0x06); // functions that help with iPhone connections issue
  pAdvertising->setMinPreferred(0x12);
  BLEDevice::startAdvertising();
  Serial.println("Characteristic defined! Now you can read it in your phone!");
  Serial.print(F("Temperature = "));
  Serial.print(bme.temperature);
  Serial.println(F(" *C"));
  Serial.print(F("Pressure = "));
  Serial.print(bme.pressure / 100.0);
  Serial.println(F(" hPa"));
  Serial.print(F("Humidity = "));
  Serial.print(bme.humidity);
  Serial.println(F(" %"));
  Serial.print(F("Gas = "));
  Serial.print(bme.gas_resistance / 1000.0);
  Serial.println(F(" KOhms"));
  Serial.print(F("Approx. Altitude = "));
  Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
  Serial.println(F(" m"));
  Serial.println();
  display.setCursor(1, 1);
  Serial.print(bme.temperature, 1);
  Serial.print(bme.humidity, 0);
  Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA), 0);
  display.print("Temp:      ");      //Show the name, you can remove it or replace it
  display.print(bme.temperature, 1); //Show the name, you can remove it or replace it
  display.println(" C");             //Show the name, you can remove it or replace it
  display.print("Humidity:  ");   //Show the name, you can remove it or replace it
  display.print(bme.humidity, 0); //Show the name, you can remove it or replace it
  display.println(" %");          //Show the name, you can remove it or replace it
  display.print(F("Pressure:  "));
  display.print((bme.pressure / 100.0) * 0.03, 0);
  display.println(F(" in Hg"));
  display.print("Altitude:  ");                             //Show the name, you can remove it or replace it
  display.print(bme.readAltitude(SEALEVELPRESSURE_HPA), 0); //Show the name, you can remove it or replace it
  display.println(" m");                                    //Show the name, you can remove it or replace it
  display.print("Gas:      ");                   //Show the name, you can remove it or replace it
  display.print(bme.gas_resistance / 1000.0, 0); //Show the name, you can remove it or replace it
  display.println(" KOhm");                      //Show the name, you can remove it or replace it
  display.display();
  delay(5000);
[env:wemos_d1_mini32]
board = wemos_d1_mini32
monitor_speed = 9600
lib_deps = Adafruit_BusIO/Adafruit_I2CDevice.h at master · adafruit/Adafruit_BusIO · GitHub
I took a working BME680 program and added a working BLE advertisement.
It looks like a URL to the wrong thing. It should probably be:
lib_deps = https://github.com/adafruit/Adafruit_BusIO.git
Or just:
lib_deps = Adafruit BusIO
… I saw that the .h file I wanted was inside BusIO.
So I should include the whole parent library?
lib_deps is the abbreviation for library dependencies. It’s for declaring libraries that are needed to build the project.
So yes, you need to specify the library and not a single include/header file.
