Stack overflow exception(29)
Hi, I am new to PlatformIO i am facing an stack overflow exception(29) error from platformIO when i upload the code( i have copied the painlessmesh example code Starthere).
if same code is uploaded through Arduino IDE It works fine can any one get me the Solution for this.
code:
#include "painlessMesh.h"
#include <ESP8266WiFi.h>
#define   MESH_PREFIX     "ThisisTechnowspro"
#define   MESH_PASSWORD   "111222333"
#define   MESH_PORT       5555
#define   LED             2       // GPIO number of connected LED, ON ESP-12 IS GPIO2
#define   BLINK_PERIOD    3000 // milliseconds until cycle repeat
#define   BLINK_DURATION  100  // milliseconds LED is on for
// WiFi credentials: should match your access point!
#define   STATION_SSID     "test1"
#define   STATION_PASSWORD "111222333"
#define HOSTNAME "MJ_Host"
// Prototypes
void sendMessage();
void receivedCallback(uint32_t from, String & msg);
void newConnectionCallback(uint32_t nodeId);
void changedConnectionCallback();
void nodeTimeAdjustedCallback(int32_t offset);
void delayReceivedCallback(uint32_t from, int32_t delay);
Scheduler     userScheduler; // to control your personal task
painlessMesh  mesh;
bool calc_delay = false;
SimpleList<uint32_t> nodes;
void sendMessage() ; // Prototype
Task taskSendMessage( TASK_SECOND * 1, TASK_FOREVER, &sendMessage ); // start with a one second interval
// Task to blink the number of nodes
Task blinkNoNodes;
bool onFlag = false;
  pinMode(LED, OUTPUT);
  mesh.setDebugMsgTypes(ERROR | DEBUG);  // set before init() so that you can see error messages
  mesh.init(MESH_PREFIX, MESH_PASSWORD, &userScheduler, MESH_PORT);
  mesh.onReceive(&receivedCallback);
  mesh.onNewConnection(&newConnectionCallback);
  mesh.onChangedConnections(&changedConnectionCallback);
  mesh.onNodeTimeAdjusted(&nodeTimeAdjustedCallback);
  mesh.onNodeDelayReceived(&delayReceivedCallback);
  // mesh.stationManual(STATION_SSID, STATION_PASSWORD);
   mesh.setHostname(HOSTNAME);
   //mesh.setRoot(true);
   mesh.setContainsRoot(true);
  userScheduler.addTask( taskSendMessage );
  taskSendMessage.enable();
  blinkNoNodes.set(BLINK_PERIOD, (mesh.getNodeList().size() + 1) * 2, []() {
      // If on, switch off, else switch on
      if (onFlag)
        onFlag = false;
      else
        onFlag = true;
      blinkNoNodes.delay(BLINK_DURATION);
      if (blinkNoNodes.isLastIteration()) {
        // Finished blinking. Reset task for next run
        // blink number of nodes (including this node) times
        blinkNoNodes.setIterations((mesh.getNodeList().size() + 1) * 2);
        // Calculate delay based on current mesh time and BLINK_PERIOD
        // This results in blinks between nodes being synced
        blinkNoNodes.enableDelayed(BLINK_PERIOD -
            (mesh.getNodeTime() % (BLINK_PERIOD*1000))/1000);
  userScheduler.addTask(blinkNoNodes);
  blinkNoNodes.enable();
  randomSeed(analogRead(A0));
  mesh.update();
  digitalWrite(LED, !onFlag);
void sendMessage() {
  String msg = "Hl fr " + String(mesh.getNodeId());
    msg += " rt " + String(mesh.isRoot());
    msg += " MAC " + String(WiFi.macAddress());
    msg += " cp id: " + String(ESP.getChipId());
    msg += " myFreeMemory: " + String(ESP.getFreeHeap());
    mesh.sendBroadcast(msg);
  if (calc_delay) {
    SimpleList<uint32_t>::iterator node = nodes.begin();
    while (node != nodes.end()) {
      mesh.startDelayMeas(*node);
      node++;
    calc_delay = false;
  Serial.printf("Sending message: %s\n", msg.c_str());
  taskSendMessage.setInterval( random(TASK_SECOND * 1, TASK_SECOND * 5));  // between 1 and 5 seconds
  // serilize json data.
  /*DynamicJsonDocument doc(1024);
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  doc["TEMP"] = t;
  doc["HUM"] = h;
  String msg ;
  serializeJson(doc, msg);
  mesh.sendBroadcast( msg );
  Serial.println(msg);
  taskSendMessage.setInterval((TASK_SECOND * 10));*/
void receivedCallback(uint32_t from, String & msg) {
  Serial.printf("startHere: Received from %u msg=%s\n", from, msg.c_str());
   // below code for deserilize json doc
  String json;
  json = msg.c_str();
  /* DeserializationError error = deserializeJson(doc, json);
  if (error)
    Serial.print("deserializeJson() failed: ");
    Serial.println(error.c_str());
  //relay1_status = doc["Relay1"];
 // digitalWrite(Relay1, relay1_status);
void newConnectionCallback(uint32_t nodeId) {
  // Reset blink task
  onFlag = false;
  blinkNoNodes.enableDelayed(BLINK_PERIOD - (mesh.getNodeTime() % (BLINK_PERIOD*1000))/1000);
  Serial.printf("--> startHere: New Connection, nodeId = %u\n", nodeId);
  Serial.printf("--> startHere: New Connection, %s\n", mesh.subConnectionJson(true).c_str());
void changedConnectionCallback() {
  Serial.printf("Changed connections\n");
  // Reset blink task
  onFlag = false;
  nodes = mesh.getNodeList();
  Serial.printf("Num nodes: %d\n", nodes.size());
  Serial.printf("Json Connection, %s\n", mesh.subConnectionJson(true).c_str());
  Serial.printf("Connection list:");
    Serial.printf(" %u", *node);
    node++;
  Serial.println();
  calc_delay = true;
void nodeTimeAdjustedCallback(int32_t offset) {
  Serial.printf("Adjusted time %u. Offset = %d\n", mesh.getNodeTime(), offset);
void delayReceivedCallback(uint32_t from, int32_t delay) {
  Serial.printf("Delay to node %u is %d us\n", from, delay);
See Platformio, ESP32 and Bluetooth - How? - #2 by maxgerhardt
