mguru
1
During linking I receive error caused by:
> .pioenvs\nucleo_l011k4\firmware.elf section ._user_heap_stack' will not fit in region
RAM’
> region `RAM’ overflowed by x bytes.
In output.map file I see that:
> .data.impure_data 0x20000000 0x428 c:/users/bzc8jx/.platformio/packages/toolchain-gccarmnoneeabi/bin/…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/lib/thumb/v6-m\libc.a(lib_a-impure.o) .data.__atexit_recursive_mutex
that is taking almoust 1k of RAM so heap and stack cannot fit (I’m using standard linker script).
How to fix it?
Regards,
Marcin
jcw
2
I too would be interested in this - the linker script for this µC with such limited memory resources probably needs to be adjusted.
UPDATE - I worked around this by editing this file: ~/.platformio/packages/framework-stm32cube/platformio/ldscripts/STM32L011K4_DEFAULT.ld
Lowering the values from 0x200/0x400 to 0x100/0x100 respectively:
_Min_Heap_Size = 0x100; /* required amount of heap */
_Min_Stack_Size = 0x100; /* required amount of stack */
And then a simple blink build works.
(but I couldn’t quite figure out where that file can be found on GitHub)
