Using esp-idf on esp32, trying to change src_dir from “src” to “main”, seems like src_dir is not being read and an hard coded “src” is read instead.
My platformio.ini:
[plafromio]
src_dir = main
[env]
framework = espidf
board_upload.flash_size = 8MB
board_upload.maximum_size=8388608
debug_tool = jlink
debug_speed = 1000
upload_protocol = jlink
Working on windows vscode I get the following message:
FileNotFoundError: [WinError 3] The system cannot find the path specified: 'C:\Users\***\Documents\PlatformIO\Projects\softAP\src’:
File "C:\Users*.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 177:
As you can see it is searching in src instead of main. This is after renaming the src dir to main.
The project is the esp-idf softAP example.
I also attach my cmakelists files
The project cmakelists:
cmake_minimum_required(VERSION 3.16.0)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
list(APPEND EXTRA_COMPONENT_DIRS etl)
project(softAP)
The main cmakelists:
file(GLOB SOURCES main.c .//.c .//.cpp)
file(GLOB APP_INCLUDE_DIRS “.” ./*/include)
idf_component_register(SRCS ${SOURCES}
INCLUDE_DIRS ${APP_INCLUDE_DIRS}
REQUIRES nvs_flash esp_adc_cal)
Please advice! thank you
