Is this intended? If so would be a nice thing to add in case i want to compile multiple different codes inside one single project.
Also heres my platformio.ini
[platformio]
default_envs = esp32dev_tx
[common]
tmrh20/RF24 ;hasnt been updated to nRF24/RF24
[env:esp32dev_tx]
src_dir = src_tx
[env:esp32dev_rx]
src_dir = src_rx
src_dir
is a global setting for the [platformio]
section and does not work per-environment.
Already possible using src_filter
. Just -<src_rx/>
and -<src_tx/>
it in the first and second env respectively.
Allowing the src_dir parameter in the env sections does more sense then the src_filter option, to me. I have been try to figure out this issue for days now, until i saw that it was ignored earlier today.
Just tried your solution but now the main.cpp is not found because the root src folder is empty, i think.
Found 34 compatible libraries
No dependencies
Error: Nothing to build. Please put your source code files to 'C:\Users\HP\Documents\PlatformIO\Projects\nowTalk\src' folder
============================= [FAILED] Took 1.28 seconds =============================
Environment Status Duration
Bridge FAILED 00:00:01.279
======================== 1 failed, 0 succeeded in 00:00:01.279 ========================The terminal process "C:\Users\HP\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'Bridge'" terminated with exit code: 1.
Feature-request can be made in Issues · platformio/platformio-core · GitHub.
Not reproducable.
If I adapt your code from Src_dir is not being read - #3 by nielsnl68, follow the documentation regarding the standard value and do it like
[platformio]
description = NowTalk
[env:CommBadge]
upload_port = COM11
src_filter = +<*> -<bridge>
[env:Bridge]
board = esp32cam
upload_port = COM8
src_filter = +<*> -<commBadge>
it works. In the CommBadge
environment I get
Processing CommBadge (platform: espressif32; board: esp32dev; framework: arduino)
Compiling .pio/build/CommBadge/src/commBadge/main.cpp.o
and in the bridge
environment I get
Processing Bridge (board: esp32cam; platform: espressif32; framework: arduino)
Compiling .pio/build/Bridge/src/bridge/main.cpp.o
That is with the folder structure
├── src
│ ├── bridge
│ │ └── main.cpp
│ └── commBadge
│ └── main.cpp
ok. i will test that, AND YES this is how it works. Thanks for the examples. Just wondering would this work as well -<*> +.
going to test that, now i have just 2 sub projects maybe later i want to add more sub projects.
I will however doe the request as well.
Yes that works as well
src_filter= -<*> +<your_sub_project>
