Hello, I have this struct that tells me what kind of interrupt numbers are valid.
InterruptVectorTable.hpp
struct ValidIRQTypes
ValueType m_size;
ValueType m_ValidTypes[];
inline ValueType size() { return m_size; };
* @brief Binary search to check if the given index is valid.
* @param InterruptNumber
* @return true
* @return false
bool IsValidIRQType(const ValueType InterruptNumber) const
ValueType i = 0;
ValueType j = m_size - 1;
if (InterruptNumber == m_ValidTypes[i] || InterruptNumber == m_ValidTypes[j])
return true;
else if (InterruptNumber < m_ValidTypes[i] || m_ValidTypes[j] < InterruptNumber)
return false;
ValueType mid = 0;
ValueType midValue = 0;
while (i < j)
mid = i + (j - i) / 2;
midValue = m_ValidTypes[mid];
if (InterruptNumber <= midValue)
j = mid - 1;
else
i = mid + 1;
return InterruptNumber == midValue;
class InterruptVectorTable
* @brief
* Singleton design pattern:
* https://stackoverflow.com/questions/1008019/c-singleton-design-pattern
private:
* @brief Construct a new Interrupt Vector Table object
InterruptVectorTable();
* @brief Destroy the Interrupt Vector Table object
~InterruptVectorTable();
* @brief This vector pointer needs to point to the Vector Table.
* The vector Table needs to have the explicit size of VectorsCount of the ValueType.
* The behaviour is undefined if the vector is accessed from with offsets that are not within the
* range [0:VectorsCount]
ValueType* m_VectorTable;
* @brief Checks whether the given IRQNumber is valid.
* @return true Is valid
* @return false Is not valid
public:
enum IRQTypes : ValueType; // forward declaration of enums with type/size specification.
const static ValidIRQTypes s_ValidIRQTypes;
bool IsValidIRQType(const ValueType IRQNumber) { return s_ValidIRQTypes.IsValidIRQType(IRQNumber); };
* @brief Deleted copy constructor
InterruptVectorTable(InterruptVectorTable const&) = delete;
* @brief Deleted asignment operator
void operator=(InterruptVectorTable const&) = delete;
* @brief Get the Singleton instance
* Aftr this instance has ben created, interrupts are enabled by default.
* @return InterruptVectorTable&
static InterruptVectorTable& getInstance()
static InterruptVectorTable instance; // Guaranteed to be destroyed.
// Instantiated on first use.
return instance;
* @brief
* @param Callback Function to be called, when the Interrupt is
bool setCallback(ValueType InterruptNumber, void (*Callback)(void));
* @brief Enables interrupts globally
void enableIRQ();
* @brief Disables Interrupts globally.
void disableIRQ();
* @brief Disable interrupt at given InterruptNumber
* @param InterruptNumber interrupt InterruptNumber, as defined in the manuals: >= 0
void enableISR(ValueType InterruptNumber);
* @brief Disable an interrupt / interrupt service routine
* @param InterruptNumber Is the InterruptNumber of the interrupt within the interrupt vctor table.
* Should be a ValueType greater than or equal to 0.
void disableISR(ValueType InterruptNumber);
* @brief Triggers a software interrupt request
void triggerIRQ(ValueType InterruptNumber);
Depending on the target a different InterruptVectorTable.cpp is compiled.
The LPC1768 has this here:
#include "LPC17xx.h"
#include "InterruptTypes.hpp"
#include <hal/InterruptVectorTable.hpp>
#include <cstring>
const ValidIRQTypes InterruptVectorTable::s_ValidIRQTypes = {
35,
0, 1, 2, 3, 4, 5, 6,
7, 8, 9, 10, 11, 12, 13,
14, 15, 16, 17, 18, 19, 20,
21, 22, 23, 24, 25, 26, 27,
28, 29, 30, 31, 32, 33, 34
The STM32F407VG has this implementation:
#include "stm32f4xx.h"
#include <cstring>
82,
0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
10, 11, 12, 13, 14, 15, 16, 17, 18,
19, 20, 21, 22, 23, 24, 25, 26, 27,
28, 29, 30, 31, 32, 33, 34, 35, 36,
37, 38, 39, 40, 41, 42, 43, 44, 45,
46, 47, 48, 49, 50, 51, 52, 53, 54,
55, 56, 57, 58, 59, 60, 61, 62, 63,
64, 65, 66, 67, 68, 69, 70, 71, 72,
73, 74, 75, 76, 77, 78, 79, 80, 81
and the ATmega328p has basically the same initializer list:
#include <string.h>
* @brief List of valid IRQ Index numbers
25,
1, 2, 3, 4, 5,
6, 7, 8, 9, 10,
11, 12, 13, 14, 15,
16, 17, 18, 19, 20,
21, 22, 23, 24, 25
except that it does not compile and seems to not properly deduce the correct size
src/target/MYAVR_BOARD_MK2/InterruptVectorTable.cpp:20:1: error: too many initializers for 'ValueType [0] {aka unsigned char [0]}'
It basically tells me that the deduced size is 0.
Does anyone know, how one would fix this on AVR-GCC?
