I am trying to include the SPIMemory library, but when I use “SPIFlash flash”, the code will not compile succesfully anymore.
Lib should also support STM32 according to the Libraries secrion of PlatformIO.
The code for STM32 I have is:
#include <SPIMemory.h>
SPIFlash flash(PA15);
flash.begin();
The result I get when compiling is:
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/JENG_STM32L082KZ.html
PLATFORM: ST STM32 (8.1.0) > JENG STM32L082KZ
HARDWARE: STM32L082KZ 32MHz, 20KB RAM, 192KB Flash
DEBUG: Current (stlink) External (blackmagic, jlink, stlink)
- framework-arduinoststm32 4.10900.200819 (1.9.0)
- framework-cmsis 2.50501.200527 (5.5.1)
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Found 13 compatible libraries
|-- <SPIMemory> 3.4.0
| |-- <SPI> 1.0
Compiling .pio\build\JENG_STM32L082KZ\src\main.cpp.o
Linking .pio\build\JENG_STM32L082KZ\firmware.elf
c:/users/jacco/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/JENG_STM32L082KZ/src/main.cpp.o: in function `_GLOBAL__sub_I_flash':
main.cpp:(.text.startup._GLOBAL__sub_I_flash+0x6): undefined reference to `SPIFlash::SPIFlash(unsigned char)'
*** [.pio\build\JENG_STM32L082KZ\firmware.elf] Error 1
I have no clue where the function “_GLOBAL__sub_I_flash” actually is and what the problem is.
When I make an ATMega328 project using the library, it does compile succesfully.
