My unity tests uses the CDC serial port of my STM32H7 which is mapped to COM6 on windows. If I run the test without specifying test_port, the tests pass. However if I do specify test_port=6, it fails to open the port and the test fails.
Any suggestions how to fix it? I wonder if this is a timing issue. If I don’t specify the port, platformio spends time to find the port which let the device sufficient time to initialize the CDC link.
(I need to specify the port because the system has additional serial ports that I need to connect).
Error message:
could not open port 'COM6': FileNotFoundError(2, 'The system cannot find the file specified.', None, 2)
Devices:
$ pio device list
COM1
Hardware ID: ACPI\PNP0501\0
Description: Communications Port (COM1)
COM6
Hardware ID: USB VID:PID=0483:5740 SER=387035733232 LOCATION=1-4.4
Description: USB Serial Device (COM6)
Platformio.ini:
[env:my_env]
build_type = debug
; build_type = release
platform = ststm32
; test_filter = serial_packets/test_serial_packets_client
; debug_test = serial_packets/test_serial_packets_client
test_filter = test_trivial
debug_test = test_trivial
extra_scripts = extra_script.py
board = my_genericSTM32H750VBT6
; Linker file is from cube ide.
board_build.ldscript = STM32H750VBTX_FLASH.ld
debug_tool = stlink
upload_protocol = stlink
; debug_build_flags = -O0 -ggdb3 -g3
; debug_build_flags = -Og -ggdb3 -g3
debug_build_flags = -Os -g3 -ggdb3
; debug_init_break = tbreak app_main
debug_init_break = tbreak none
test_framework = unity
test_port = COM6
monitor_port = COM6
lib_archive = no
check_skip_packages = yes
adc
data_recorder
host_link
io
misc
printer_link
controller
cube_ide
serial_packets
system
-fmax-errors=5
-Werror
-mfpu=fpv5-sp-d16
-mfloat-abi=hard
-Wl,-Map,${BUILD_DIR}/firmware.map
-mthumb
-D DEBUG
-D USE_HAL_DRIVER
-DSTM32_THREAD_SAFE_STRATEGY=4
-fstack-usage
-std=gnu11
-Ilib/cube_ide/Core/Inc
-Ilib/cube_ide/Core/ThreadSafe
-Ilib/cube_ide/Drivers/CMSIS/Device/ST/STM32H7xx/Include
-Ilib/cube_ide/Drivers/CMSIS/Include
-Ilib/cube_ide/Drivers/STM32H7xx_HAL_Driver/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Core/Inc
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2/Include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F
-Ilib/cube_ide/Middlewares/Third_Party/FatFs/src
-Ilib/cube_ide/USB_DEVICE/App
-Ilib/cube_ide/USB_DEVICE/Target
-Ilib/cube_ide/FATFS/App
-Ilib/cube_ide/FATFS/Target
-D CONFIG_MAX_PACKET_DATA_LEN=1000
-D CONFIG_MAX_PENDING_COMMANDS=5
Log with test_port=COM6 (test fails):
~/projects/daq/repo/controller$ cd platformio/
~/projects/daq/repo/controller/platformio$ pio test
Verbosity level can be increased via `-v, -vv, or -vvv` option
Collected 10 tests
Processing test_trivial in my_env environment
Building & Uploading...
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
hla_swd
[stm32h7x.cpu0] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08001958 msp: 0x24080000
** Programming Started **
Warn : Adding extra erase range, 0x0800c520 .. 0x0801ffff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
Testing...
If you don't see any output for the first 10 secs, please reset board (press reset button)
------------------------------------------------------------ my_env:test_trivial [PASSED] Took 25.62 seconds ------------------------------------------------------------
=============================================================== 0 test cases: 0 succeeded in 00:00:25.618 ===============================================================
