I am attempting to use the most recent master
branch of the arduino-esp32 core from Github.
To achieve this, I added the platform-packages =
line to platformio.ini:
[env]
platform_packages =
framework-arduino-esp32 @ https://github.com/espressif/arduino-esp32
board = az-delivery-devkit-v4
monitor_port = COM3
board_build.partitions = default.csv
debug_tool = esp-prog
The Framework supposedly was installed:
Tool Manager: Installing git+https://github.com/espressif/arduino-esp32
git version 2.27.0.windows.1
Cloning into 'C:\Users\Micha\.platformio\.cache\tmp\pkg-installing-44wqqrye'...
remote: Enumerating objects: 5301, done.
remote: Counting objects: 100% (5301/5301), done.
remote: Compressing objects: 100% (3585/3585), done.
remote: Total 5301 (delta 1569), reused 3074 (delta 1130), pack-reused 0
Receiving objects: 100% (5301/5301), 185.31 MiB | 6.11 MiB/s, done.
Resolving deltas: 100% (1569/1569), done.
Updating files: 100% (10009/10009), done.
Tool Manager: framework-arduino-esp32@2.0.4+sha.d1c10d9 has been installed!
But when compiling, I get the error
lib/eModbus/src/RTUutils.cpp: In static member function 'static int RTUutils::UARTinit(HardwareSerial&, int)':
lib/eModbus/src/RTUutils.cpp:126:10: error: 'class HardwareSerial' has no member named 'setRxFIFOFull'
serial.setRxFIFOFull(1);
that indicates the alternate framework was not used.
What am I missing here?
