The log2file filter’s log path is defined as
so it will always log to the <current directory>/platformio-device-monitor-<data>.log
file. If you want to log to a different directory, you woudl have to change <current directory>
by invoking the PlatformIO monitor / run command from a different folder.
cd /logs
pio run -d <your original project path> -t monitor
For everything else, file an issue in Issues · platformio/platformio-core · GitHub.
