I’ve just purchased a sparkfun esp32-wroom-32ue, and I’m trying to get it to work with PIO. Here’s my sketch:
int ledPin = 13;
pinMode(ledPin, OUTPUT);
Serial.begin(9600);
Serial.print("Hello");
digitalWrite(ledPin, HIGH);
delay(500);
Serial.println(" world!");
digitalWrite(ledPin, LOW);
delay(500);
Works great using the Arduino-IDE. Builds fine on PIO, but when I go to deploy -
> Executing task in folder Sparkfun Thing: C:\Users\greg\.platformio\penv\Scripts\pio.exe run --target upload <
Processing sparkfun_samd51_thing_plus (platform: atmelsam; board: sparkfun_samd51_thing_plus; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/sparkfun_samd51_thing_plus.html
PLATFORM: Atmel SAM (5.1.1) > SparkFun SAMD51 Thing Plus
HARDWARE: SAMD51J20A 120MHz, 192KB RAM, 496KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, jlink)
- framework-arduino-samd-sparkfun 1.7.5
- framework-cmsis 1.40500.0 (4.5.0)
- framework-cmsis-atmel 1.2.0
- tool-bossac 1.10700.190624 (1.7.0)
Found 8 compatible libraries
Checking size .pio\build\sparkfun_samd51_thing_plus\firmware.elf
RAM: [ ] 1.1% (used 2228 bytes from 196608 bytes)
Flash: [ ] 2.2% (used 10928 bytes from 507904 bytes)
AVAILABLE: atmel-ice, jlink, sam-ba
CURRENT: upload_protocol = sam-ba
Looking for upload port...
Auto-detected: COM10
Forcing reset using 1200bps open/close on port COM10
Waiting for the new upload port...
Uploading .pio\build\sparkfun_samd51_thing_plus\firmware.bin
SAM-BA operation failed
*** [upload] Error 1
========================================================================================= [FAILED] Took 10.99 seconds =========================================================================================
The terminal process "C:\Users\greg\.platformio\penv\Scripts\pio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
Googling for ‘SAM-BA operation failed’ turns up very little. Any nudge in the right direction would be greatly appreciated. Thanks!
GregM
