Error: Can not install ‘atmelavr’ with version requirements
’ * ’ for your system ‘windows_x86’
Also have two deprecations (bottom right) argument to ‘path.extname’ must be a string
NB: Installed without reading. So i uninstalled then followed the install instructions (as you should).
May have messed up, because i think the uninstall did not remove all associations? Not a fresh install.
I do as you requested, disable McAfee during the first initialization build project.
No change:
Guess the next question, what are the version requirements?
