I believe that it’s supposed to be in but when I try to include it I am getting an error. However, the file cmath does exist because I can do right-click jump to its definition and I can set in on disk.
~$ ls -l .platformio/packages//toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/8.2.1/cmath
-rw-r--r-- 1 user 197121 48142 Feb 13 2019 .platformio/packages//toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/8.2.1/cmath
main.cpp
#include <zephyr.h>
#include <cmath>
void main(void) {
for (int i = 6;; i++) {
printk("%d\n", i);
k_msleep(500);
build log:
> Executing task: C:\Users\user\.platformio\penv\Scripts\platformio.exe run <
Processing nrf52_dk (platform: nordicnrf52; board: nrf52_dk; framework: zephyr)
-------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/nrf52_dk.html
PLATFORM: Nordic nRF52 (9.3.0) > Nordic nRF52-DK
HARDWARE: NRF52832 64MHz, 64KB RAM, 512KB Flash
DEBUG: Current (jlink) On-board (cmsis-dap, jlink) External (blackmagic, stlink)
- framework-zephyr 2.20701.220216 (2.7.1)
- tool-cmake 3.21.3
- tool-dtc 1.4.7
- tool-ninja 1.9.0
- tool-sreccat 1.164.0 (1.64)
- toolchain-gccarmnoneeabi 1.80201.190214 (8.2.1)
Found 0 compatible libraries
Compiling .pio\build\nrf52_dk\src\main.o
src\main.cpp:3:10: fatal error: cmath: No such file or directory
#include <cmath>
compilation terminated.
*** [.pio\build\nrf52_dk\src\main.o] Error 1
===================================== [FAILED] Took 5.73 seconds =====================================
The terminal process "C:\Users\user\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
platformio.ini:
[env:nrf52_dk]
platform = nordicnrf52
board = nrf52_dk
framework = zephyr
debug_tool = jlink
