using Eclipse for ARM M4 code ok,
using PIO ARM M3 error code.
table saved functions poiters in flash,
void f01(uint32_t);
void f02(uint32_t);
uint32_t f03(void);
const uint32_t tablefunc[] = {(uint32_t*)&f01, // error with PIO
(uint32_t*)&f02,
(uint32_t*)&f03,
void (*ram_call)(uint32_t);
ram_call = (uint32_t) tablefunc[ 0 ]; // call f01
ram_call( 1); ok
using PIO not compiling.
thanks,
Carlos
Carlos_Candido:
(uint32_t*)&f02,
(uint32_t*)&f03,
You’ve declared an array of uint32_t
elements but then put uint32_t*
elements in it. Type error. Either change the type to uint32_t*
or cast each element to (uint32_t)
maxgerhardt:
(uint32_t*)&f02,
(uint32_t*)&f03,
to
(uint32_t)&f01,
(uint32_t)&f02,
(uint32_t)&f03,
runing ok
thanks,
Carlos.
