[SOLVED] Error including EEPROM.h in Digispark-USB project
Well the EEPROM.h is really not there / included by default for the digispark-tiny board.
However, the EEPROM.h really is just a fancy wrapper for eeprom_write_byte() / eeprom_read_byte() from avr/eeprom.h. To be found here. You can just put this file in your src/ folder and then program as normal.
#include <EEPROM.h>
	Serial.begin(9600);
	Serial.println("Write");
	EEPROM.begin();
	EEPROM.write(0, 0xAB);
	Serial.println("Readback");
	uint8_t readback = EEPROM.read(0);
	Serial.println(readback, HEX);
