PlatformIO Core 5.0.4 Home 3.3.1
SUSE Leap 15.2
The hardware is a ESP32-WROOM-32D module on a “no-name” burner board.
[platformio]
description = My Blink
lib_extra_dirs = ~/Documents/Arduino/libraries
upload_protocol = esp-prog
upload_port = /dev/ttyUSB1
upload_speed = 115200
monitor_port = /dev/ttyUSB1
debug_tool = esp-prog
debug_port = /dev/ttyUSB0
debug_init_break = tbreak
My Debug Console…
Preparing firmware for debugging...
PLATFORM: Espressif 32 (2.1.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10004.201016 (1.0.4)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-openocd-esp32 2.1000.20201202 (10.0)
Found 26 compatible libraries
Building in debug mode
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
RAM: [ ] 4.7% (used 15444 bytes from 327680 bytes)
Flash: [== ] 16.5% (used 216797 bytes from 1310720 bytes)
========================= [SUCCESS] Took 1.93 seconds =========================
undefinedOpen On-Chip Debugger v0.10.0-esp32-20201202 (2020-12-02-17:38)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
Info : FreeRTOS creation
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Reading symbols from /home/mprowe/Documents/PlatformIO/Projects/myBlink_FT231/.pio/build/esp32dev/firmware.elf...
done.
PlatformIO: debug_tool = esp-prog
/dev/ttyUSB0: No such file or directory.
I know that it (last line above) reports that there is a problem with /dev/ttyUSB0!
But before I try running Debug (Run | Start Debugging) both ports on the ESP_Prog are reported.
After the debug port (/dev/ttyUSB0) vanishes following the failed debug session, if I close and reopening PIO, /dev/ttyUSB0 is back again.
And lastly, I’m fairly sure that my setup was working fine only a week ago?
Regards, M.
