Sipeed RV-Debugger Lite
For completness a terminal excerpt showing the improvments:-
Uploading .pio/build/sipeed-longan-nano-lite/firmware.elf
Open On-Chip Debugger 0.10.0+dev-00911-gcfbca74bd (2019-09-12-09:31)
Licensed under GNU GPL v2
For bug reports, read
Warn : Transport "jtag" was already selected
jtag
adapter speed: 1000 kHz
Info : clock speed 1000 kHz
Info : JTAG tap: riscv.cpu tap/device found: 0x1000563d (mfg: 0x31e (Andes Technology Corporation), part: 0x0005, ver: 0x1)
Info : JTAG tap: gd32v.tap tap/device found: 0x790007a3 (mfg: 0x3d1 (GigaDevice Semiconductor (Beijing)), part: 0x9000, ver: 0x7)
Info : datacount=4 progbufsize=2
Info : Examined RISC-V core; found 1 harts
Info :  hart 0: XLEN=32, misa=0x40901105
Info : Listening on port 3333 for gdb connections
Info : device id = 0x19060410
Info : flash_size_in_kb = 0x00000040
Info : flash size = 64kbytes
** Programming Started **
** Programming Finished **
** Verify Started **
** Verified OK **
Info : Hart 0 unexpectedly reset!
*** [upload] Error 1
Just to show the difference against the foregoing excerpts. This was programming a longan nano lite and the flash size is correctly reported as 64K. Programing the longan nano the flash size is also now correctly reported as 128K in the terminal session…
