I am new to Atom and PlatformIO and Git…
I am using Atom/PlatformIO on a Windows 10 machine, where I develop.
I have a number of controllers on my property, doing all sorts of automation.
When I need to update a firmware, I copy the main.c to a share; I then log into the notebook and create a project with the same name and copy the shared main.c into the project, compile and upload to the controller out in the field.
So far so good.
However, I want to m igrate to Linux and would then need a third environment, which would become a burden to keep three environments in sync.
For those using a Mozilla product, the profiles can be shared between machines. Is there a similar approach I can use with the Atom/PlatformIO environments? I am happy to manually synchronise the Atom/Platformio bit, with libraries and all, but at least would like to share the project directory “.platformIO” between these systems?
Or is this a Git think I have to figure out? – The problem here is the steep learning curve for an old fellow
Any pointers appreciated.
