I’m trying to flash a new firmware to an ATmega328p(-pu), it seemed to work previously, like one week ago, but now it gives me this error, which I cannot interpret:
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega328P.html
PLATFORM: Atmel AVR 2.0.0 > ATmega328P/PA
PACKAGES: toolchain-atmelavr 1.50400.190710 (5.4.0), tool-avrdude 1.60300.190628 (6.3.0)
Found 0 compatible libraries
Building in debug mode
MethodWrapper(["checkprogsize"], [".pio/build/atmega328p/firmware.elf"])
DATA: [ ] 2.9% (used 60 bytes from 2048 bytes)
PROGRAM: [= ] 7.6% (used 2464 bytes from 32256 bytes)
.pio/build/atmega328p/firmware.elf :
section size addr
.data 0 8388864
.text 2464 0
.bss 60 8388864
.comment 47 0
.note.gnu.avr.deviceinfo 64 0
.debug_aranges 32 0
.debug_info 3832 0
.debug_abbrev 2165 0
.debug_line 1263 0
.debug_frame 2444 0
.debug_str 2627 0
.debug_loc 5585 0
.debug_ranges 96 0
Total 20679
<lambda>(["upload"], [".pio/build/atmega328p/firmware.hex"])
AVAILABLE: avr911
CURRENT: upload_protocol = avr911
BeforeUpload(["upload"], [".pio/build/atmega328p/firmware.hex"])
Use manually specified: /dev/cu.SLAB_USBtoUART
avrdude -e +<*> -<.git/> -<.svn/> -<example/> -<examples/> -<test/> -<tests/> -<target/> -<controllers/> -<shared/> -std=c++1z -std=gnu++1z -v -p atmega328p -C /Users/john/.platformio/packages/tool-avrdude/avrdude.conf -c avr911 -b 19200 -D -P "/dev/cu.SLAB_USBtoUART" -U flash:w:.pio/build/atmega328p/firmware.hex:i
sh: *: No such file or directory
*** [upload] Error 1
PlatformIO.ini:
[platformio]
default_envs = stm32f407vg
[common]
default_src_filter =
-<.git/>
-<.svn/>
-<example/>
-<examples/>
-<test/>
-<tests/>
-<target/>
-<controllers/>
-<shared/>
# C++17 is needed for inline static definitions.
# if no inline static is used, these flags can be omitted
-std=c++1z
-std=gnu++1z
[env:stm32f407vg]
platform = ststm32
board = disco_f407vg
;framework = cmsis
src_filter =
${common.default_src_filter}
+<controllers/stm32f407vg/>
build_type = debug
${common.build_flags}
-D STM32F407VG
-D stm32f407vg
-D DEBUG
;-Wl,-T"scripts/controllers/stm32f407vg/STM32F407VG.ld"
upload_protocol = stlink
upload_port = /dev/cu.usbmodem14103
debug_tool = stlink
[env:lpc1768]
platform = nxplpc
board = lpc1768
src_filter =
+<controllers/lpc1768/>
build_type = debug
-Wl,-T"scripts/controllers/lpc1768/LPC1768.ld"
-D LPC1768
-D lpc1768
-D MCB1760
-D DEBUG
extra_scripts = scripts/controllers/lpc1768/firmware_patch.py
# J-Link Probe
upload_protocol = jlink-jtag
debug_tool = jlink
# ULINK-ME Probe - the probe that comes with the development board, literally not usable
;upload_protocol = custom
;upload_flags =
; -f
; scripts/interface/cmsis-dap.cfg
; -f
; scripts/board/mcb1700.cfg
;debug_tool = custom
;debug_server =
; $PLATFORMIO_CORE_DIR/packages/tool-openocd/bin/openocd
; -f
; ../scripts/interface/cmsis-dap.cfg
; -f
; ../scripts/board/mcb1700.cfg
# Blackmagic Probe - open source is sometimes not the best solution, as it took ages to find a working BMP firmware that works with the board.
;upload_protocol = blackmagic
;upload_port = /dev/cu.usbmodem79AC68971
;debug_port = /dev/cu.usbmodem79AC68971
;debug_init_cmds =
; target extended-remote $DEBUG_PORT
; monitor swdp_scan
; attach 1
; set mem inaccessible-by-default off
; $INIT_BREAK
; $LOAD_CMDS
[env:atmega328p]
board = ATmega328P
src_filter =
+<controllers/atmega328p/>
build_type = debug
# build and debugging flags
-D ATMEGA328P
-D atmega328p
-D DEBUG
# upload port.
upload_port = /dev/cu.SLAB_USBtoUART
upload_speed = 19200
upload_flags = -e
I don’t know if the recent updates might have caused this breaking change?
