Hi there, this is my first post.
I am working with different ESP32 boards (Heltec, DEVKITV1,…) some of them need different crystal speed. Heltec, for example, needs 26Mhz.
So when I change that in sdkconfig.h
from
#define CONFIG_ESP32_XTAL_FREQ 40
to
#define CONFIG_ESP32_XTAL_FREQ 26
then this is only valid for Heltec boards. But not for the others which needs 40 MHz.
How can I solve that challenge?
Thank you in advance
If these boards always need a different CONFIG_ESP32_XTAL_FREQ
I would rather open an issue at GitHub - platformio/platform-espressif32: Espressif 32: development platform for PlatformIO so that this error gets corrected.
Thank you for that, I created an issue:
Just remove this line from sdkconfig.h
and use build_flags.
[env:Heltec]
build_flags = -D CONFIG_ESP32_XTAL_FREQ=26
[env:DEVKITV1]
build_flags = -D CONFIG_ESP32_XTAL_FREQ=99999
