When my ESP32 starts up, the first 2.5seconds of any serial output is lost.
Here is an experiment. The first lines of my setup() are:
ESP_LOGE("kinimain", "App started!");
uint32_t waitSome = millis();
uint32_t nowMillis;
while ((nowMillis = millis()) < waitSome + 3500) {
delay(100);
ESP_LOGE("kinimain", "delay %ld", nowMillis - waitSome);
What I see in the VsCode/PIO monitor when I turn the device on:
Reconnecting to /dev/cu.usbmodem831401 .... Connected!
[ 2702][E][KiniMain.cpp:102] setup(): [kinimain] delay 2405
[ 2802][E][KiniMain.cpp:102] setup(): [kinimain] delay 2506
[ 2902][E][KiniMain.cpp:102] setup(): [kinimain] delay 2606
[ 3002][E][KiniMain.cpp:102] setup(): [kinimain] delay 2706
[ 3102][E][KiniMain.cpp:102] setup(): [kinimain] delay 2806
[ 3202][E][KiniMain.cpp:102] setup(): [kinimain] delay 2906
[ 3302][E][KiniMain.cpp:102] setup(): [kinimain] delay 3006
[ 3402][E][KiniMain.cpp:102] setup(): [kinimain] delay 3106
[ 3502][E][KiniMain.cpp:102] setup(): [kinimain] delay 3206
[ 3602][E][KiniMain.cpp:102] setup(): [kinimain] delay 3306
[ 3702][E][KiniMain.cpp:102] setup(): [kinimain] delay 3406
If I reset the device while it is plugged in and outputting to serial:
Disconnected (read failed: [Errno 6] Device not configured)
Reconnecting to /dev/cu.usbmodem831401 . Connected!
[ 1602][E][KiniMain.cpp:102] setup(): [kinimain] delay 1305
[ 1702][E][KiniMain.cpp:102] setup(): [kinimain] delay 1406
[ 1802][E][KiniMain.cpp:102] setup(): [kinimain] delay 1506
[ 1902][E][KiniMain.cpp:102] setup(): [kinimain] delay 1606
[ 2002][E][KiniMain.cpp:102] setup(): [kinimain] delay 1706
[ 2102][E][KiniMain.cpp:102] setup(): [kinimain] delay 1806
[ 2202][E][KiniMain.cpp:102] setup(): [kinimain] delay 1906
[ 2302][E][KiniMain.cpp:102] setup(): [kinimain] delay 2006
[ 2402][E][KiniMain.cpp:102] setup(): [kinimain] delay 2106
[ 2502][E][KiniMain.cpp:102] setup(): [kinimain] delay 2206
[ 2602][E][KiniMain.cpp:102] setup(): [kinimain] delay 2306
[ 2702][E][KiniMain.cpp:102] setup(): [kinimain] delay 2406
For some reason, it takes 2 seconds or more to start receiving serial output, when the device is first powered on, and 1 second if the device is restarted, severing the serial connection and reconnecting to it.
Why I think this is something that could be done better, is this command line hack:
while true;
do
cu -l /dev/cu.usbmodem831401 -s 115200
done
When I turn the power on to the attached device:
cu: /dev/cu.usbmodem831401: Line in use
Connected.
[ 599][E][KiniMain.cpp:102] setup(): [kinimain] delay 299
[ 699][E][KiniMain.cpp:102] setup(): [kinimain] delay 399
[ 799][E][KiniMain.cpp:102] setup(): [kinimain] delay 499
[ 899][E][KiniMain.cpp:102] setup(): [kinimain] delay 599
[ 999][E][KiniMain.cpp:102] setup(): [kinimain] delay 699
[ 1099][E][KiniMain.cpp:102] setup(): [kinimain] delay 799
[ 1199][E][KiniMain.cpp:102] setup(): [kinimain] delay 899
[ 1299][E][KiniMain.cpp:102] setup(): [kinimain] delay 999
[ 1399][E][KiniMain.cpp:102] setup(): [kinimain] delay 1099
How can I get that better performance of about ~300ms?
What gets output during the first second is important, and right now I have to put in a delay of about 2.5seconds to ensure that I don’t miss anything. And sadly I miss anything output prior to my app getting started by the OS (If I do a esp_restart() or a crash, I get to see the initial output since there seems to be no serial port detach/reattach).
BTW, I am using a custom ESP32 board with JTAG.
