This code builds fine, and it looks like the ESP Now thinks it’s working again.
But I can’t upload with my sensors connected.
And when I upload this code, when I power the I2C sensors, I get normal-looking serial output (the sensors aren’t sensing anything…). When I power the 5V LPG sensor, I get gibberish:
Last Packet Send Status: Delivery Fail
KR��B�C�KR����r9C�)�
�������I�����b��C�IR�z�愥��)��!����)�
� -c����)�
I’m using a WeMos D1 Mini/32. The errors I was getting until I got the script to act like it was working all pointed at Adafruit BusIO, with its I2CDevice. Actually, it pointed to line 73 of 12CDevice.cpp.
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp32-esp-now-wi-fi-web-server/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <esp_now.h>
#include <esp_wifi.h>
#include <WiFi.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include "Adafruit_SGP30.h"
Adafruit_SGP30 sgp;
Adafruit_BME680 bme;
#define BOARD_ID 1
//MAC Address of the receiver
uint8_t broadcastAddress[] = {0x3C, 0x61, 0x05, 0x12, 0x84, 0x28};
//Structure example to send data
//Must match the receiver structure
typedef struct struct_message
int id;
float temperature;
float humidity;
float pressure;
float LPG;
float CO;
float smoke;
float moisture;
float UV;
float CO2;
float NH3;
float NO2;
float VOC;
float TVOC;
float H2;
float EtOH;
int readingId;
} struct_message;
//Create a struct_message called myData
struct_message myData;
unsigned int readingId = 0;
// Insert your SSID
constexpr char WIFI_SSID[] = "TP-Link_7C28";
int32_t getWiFiChannel(const char *ssid)
if (int32_t n = WiFi.scanNetworks())
for (uint8_t i = 0; i < n; i++)
if (!strcmp(ssid, WiFi.SSID(i).c_str()))
return WiFi.channel(i);
return 0;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status)
Serial.print("\r\nLast Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void setup()
Serial.begin(9600);
while (!Serial)
Serial.println(F("BME680 test"));
if (!bme.begin())
Serial.println(F("BME680 not found"));
while (1)
Serial.println("SGP30 test");
if (!sgp.begin())
Serial.println("SGP30 not found :(");
while (1)
// Set device as a Wi-Fi Station and set channel
WiFi.mode(WIFI_STA);
int32_t channel = getWiFiChannel(WIFI_SSID);
WiFi.printDiag(Serial); // Uncomment to verify channel number before
esp_wifi_set_promiscuous(true);
esp_wifi_set_channel(channel, WIFI_SECOND_CHAN_NONE);
esp_wifi_set_promiscuous(false);
WiFi.printDiag(Serial); // Uncomment to verify channel change after
//Init ESP-NOW
if (esp_now_init() != ESP_OK)
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
//Register peer
esp_now_peer_info_t peerInfo;
memset(&peerInfo, 0, sizeof(peerInfo));
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.encrypt = false;
//Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK)
Serial.println("Failed to add peer");
return;
pinMode(A0, INPUT);
void calibrate()
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
void loop()
float CO2 = sgp.eCO2;
float H2 = sgp.rawH2;
float EtOH = sgp.rawEthanol;
float VOC = bme.gas_resistance/1000;
float TVOC = sgp.TVOC;
float temperature = bme.temperature;
float humidity = bme.humidity;
float pressure = bme.pressure;
float CO = 0;
float LPG = 0;
float NH3 = 0;
float NO2 = 0;
for (int i = 0; i < 100; i++)
LPG = LPG + analogRead(36);
LPG = LPG / 25006; // get average reading
delay(50);
CO = CO + analogRead(39);
CO = CO / 25006; // get average reading
delay(50);
NH3 = NH3 + analogRead(34);
NH3 = NH3 / 25006; // get average reading
delay(50);
NO2 = NO2 + analogRead(38);
NO2 = NO2 / 25006; // get average reading
delay(50);
float readingId = readingId++;
// Set values to send
myData.id = BOARD_ID;
myData.temperature = temperature;
myData.humidity = humidity;
myData.pressure = pressure;
myData.LPG = LPG;
myData.CO = CO;
myData.smoke = 0;
myData.moisture = 0;
myData.UV = 0;
myData.CO2 = CO2;
myData.NH3 = NH3;
myData.NO2 = NO2;
myData.VOC = VOC;
myData.TVOC = TVOC;
myData.H2 = H2;
myData.EtOH = EtOH;
myData.readingId = readingId;
// Send message via ESP-NOW
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *)&myData, sizeof(myData));
if (result == ESP_OK)
Serial.println("Sent with success");
else
Serial.println("Error sending the data");
Serial.print(F("Temperature ="));
Serial.print(temperature, 0);
Serial.println(F(" *C"));
Serial.print(F("Humidity = "));
Serial.print(humidity, 0);
Serial.println(F(" %"));
Serial.print(F("LPG = "));
Serial.println(LPG, 0);
Serial.print(F("H2 = "));
Serial.println(H2, 0);
Serial.print(F("TVOC = "));
Serial.println(TVOC, 0);
delay(1000);
