Seeking Assistance to Resolve ESP32-S3-WROOM-1 Configuration Issue in PlatformIO (VS Code)
I am using the ESP32-S3-WROOM-1 module in VS Code with PlatformIO. I initially selected Espressif esp32-s3-devkitC-1-N8 (8MB QD, No PSRAM) and also tried selecting Espressif esp32-s3-devkitM-1, but I did not get any output. Later, someone suggested the configuration mentioned below, but even after applying it, I am still facing issues. I have described what appears on the serial monitor below.
// put function declarations here:
int myFunction(int, int);
int result;
result = myFunction(2, 3);
Serial.println( result);
delay(3000);
// put function definitions here:
int myFunction(int x, int y) {
return x + y;
I am now receiving output in the serial monitor.
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0xb (SPI_FAST_FLASH_BOOT)
Saved PC:0x403cdb0a
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x4bc
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a0c
entry 0x403c98d0
Build:Mar 27 2021
Saved PC:0x403cdb0a
SPIWP:0xee
entry 0x403c98d0
Build:Mar 27 2021
Saved PC:0x403cdb0a
SPIWP:0xee
lo�ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
This is my configuration setup.
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
board_build.arduino.memory_type = qio_qspi
board_build.flash_mode = qio
board_build.psram_type = qio
board_upload.flash_size = 4MB
board_upload.maximum_size = 4194304
board_build.extra_flags =
-DBOARD_HAS_PSRAM
These are the details of my controller.
In my custom board, I am using the **ESP32-S3-WROOM-1** module, and the following details are mentioned on the board:
* **ESPRESSIF**
* **ESP32-S3-WROOM-1**
* **CCAF22Y10170T3**
* **FCC ID**: 2AC7Z - ESPS3WROOM1
* **IC21098**: ESPS3WROOM1
* **CMIIT ID**: 2022DP2892
* **MCN4R2**
I’m doing the same thing in Arduino and getting output, but I’m not getting any output in VS Code.
This is the default settings image from Arduino.
I would greatly appreciate any assistance in resolving this issue, as I am a fresher and still learning how to use this platform effectively.
