// google suggested this one. It helps on the compiler, but does not yield anything in the serial monitor
//#include "Adafruit_TinyUSB.h"
pinMode(LED_BUILTIN, OUTPUT);
Serial.println("hello world");
digitalWrite(LED_BUILTIN, ! digitalRead(LED_BUILTIN));
delay(500);
Compiler cant find Serial
.pio/build/xiaoble_adafruit/src/main.cpp.o: In function `setup':
main.cpp:(.text.setup+0x8): undefined reference to `Adafruit_USBD_CDC::begin(unsigned long)'
main.cpp:(.text.setup+0x18): undefined reference to `Serial'
.pio/build/xiaoble_adafruit/src/main.cpp.o: In function `loop':
main.cpp:(.text.loop+0x2c): undefined reference to `Serial'
*** [.pio/build/xiaoble_adafruit/firmware.elf] Error 1
If I use the mbed variant it will compile, but then I am not able to get into the 5uA region when sleeping in delay()
As code hints, I have including the Adafruit_TinyUSB.h, bit it didn’t really help
static int i = 0;
Serial.print("hello new blinky world: ");
Serial.println(i++);
delay(500);
Still I get nothing in the Serial Monitor. Then by chance I hit Enter and notice a line of output.
It appears that sometimes if I send something, enter and random keys seems to work, on the monitor my code will output a line. My new program include a counter, and this shows that a lot of lines has been skipped. Furthermore sometimes I receive a garbled line.
An example from my Serial Monitor
hello new blinky world: 697
hello new blinky world: 698
hello new blinky world: 700
hello new blinky world: 701
hello new blinky world: 702
␜�pzbOȶM�w�{���hello new blinky world: 1508
hello new blinky world: 1525
I tried monitor_dtr = 1, monitor_dtr = 0, and without at all.
1 and none yields this “can be induced” behavior whereas 0 appears to give no output no matter what I do.
I tried the same configuration and code on a windows instead of my linux, and this seems to work much better. There must be something funky going on in my aging linux installation
