I use the arduino DUE for quite some time, but more recently on PIO. But to try something, I but a [[nodiscard]] atribute to a function to see the error result. But to my surprise, it work. But this is a c++14 feature. And tried the same function in arduino IDE and get there the error of c++11, that the attibute is ignore (more expected).
Is PIO use another SAM3x compiler then arduino use ?
If you want to try C++14 features, you must unset the default -std=gnu++11 switch and replace ith with c++14. As can be seen in build_flag and build_unflags docs, write in the platformio.ini
Compiling .pio\build\due\src\main.cpp.o
src\main.cpp:4:12: warning: 'nodiscard' attribute applied to 'void setup()' with void return type [-Wattributes]
and with it, no error at all, and in the “Verbose Build” you can see the invocation being arm-none-eabi-g++ -o .pio\build\due\src\main.cpp.o -c -std=c++14 -fno-rtti [...].
It is not that I so want to use c++14 feature (may be one day…), but that I was very surprise that nodiscard works on PIO, because in verbose , it is said it is compiling c++11…
Is that some feature of ++14 have been introduce before by peace ?
I could now see that the version differ from the arduino version (I add once have to use SAMD compiler for a DUE sketch because of a bug…) but I did not find what outside bugfix are change between them…
