I’m using VSCode & PlatformIO. My arduino project is multiple .ino files. Autocomplete works just fine within a single file, but won’t pull in variables from other files in the same project. Is there an include I’m missing somewhere? I assumed it should work since they’re all in the same project.
In C/C++ you need to define your macros in each file you need to use them. The Arduino IDE does this for you.
So,
#define LED_BUILTIN 13
needs to be in each source file which references LED_BUILTIN
. You can put this sort of thing in a separate header file and #include
it as required.
Alternatively, you can add the following to platformio.ini
build_flags=-DLED_BUILTIN 13
it will then be defined in every file that gets compiled.
If you have an actual variable in one source file:
const int ledPin = 13;
Then you need to add:
extern int ledPin;
to each and every source or header file which references it.
HTH
Cheers,
Norm.
