I am trying to upload a simple blink sample to a Redbear BLE Nano v2 board from a Windows 10 machine. The upload fails and I get an “OpenOCD init failed” error. Any ideas on how I can fix/workaround this?
I have attached the log below:
thanks,
λ pio run --target upload
[01/03/18 21:18:36] Processing redbear_blenano2 (platform: nordicnrf52; board: redbear_blenano2; framework: arduino)
------------------------------------------------------------------------------------- Verbose mode can be enabled via `-v, --verbose` option
Collected 2 compatible libraries
Looking for dependencies...
Uploading .pioenvs\redbear_blenano2\firmware.hex
GNU ARM Eclipse 64-bits Open On-Chip Debugger 0.10.0-00114-g8419536 (2017-04-18-21:56)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
adapter speed: 10000 kHz
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 1.0
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : reduce speed request: 10000kHz to 5000kHz maximum
Info : clock speed 10000 kHz
in procedure 'program'
in procedure 'init' called at file "embedded:startup.tcl", line 495
in procedure 'ocd_bouncer'
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
============================= [ERROR] Took 2.21 seconds =============================
===================================== [SUMMARY] ===================================== Environment redbear_blenano2 [ERROR]
Environment redBearLabBLENano [SKIP]
============================= [ERROR] Took 2.23 seconds =============================
