Recompiling Source Code w/ a different library
Hi, me and my classmates are using this tutorial to build an AI gas sensor for our high school senior capstone engineering project. The project allows for us to change the AI inference model to one of our own design to suit our unique project objectives, and the creator of the tutorial provided his source code and original firmware for users to download and modify. We’ve been following his tutorial with success, till the last step that requires us to recompile the source code with our custom made inference library into usable firmware for our WIO terminal. We can’t get the code to recompile successfully at all.
The tutorial just tells us to use the command pio run without any further direction (frustratingly vague), but we’ve tried to use VS code w/ platformio extension to recompile the code instead, which is where we’re running into our errors
Here is the error we are receiving:
Assembler messages:
Fatal error: can't create .pio\build\seeed_wio_terminal\lib056\ei-artificial_nose-arduino\edge-impulse-sdk\CMSIS\NN\Source\ConvolutionFunctions\arm_depthwise_separable_conv_HWC_q7_nonsquare.c.o: No such file or directory
*** [.pio\build\seeed_wio_terminal\lib056\ei-artificial_nose-arduino\edge-impulse-sdk\CMSIS\NN\Source\ConvolutionFunctions\arm_depthwise_separable_conv_HWC_q7_nonsquare.c.o] Error 1
Here is our platform.ini:
[env:seeed_wio_terminal]
platform = https://github.com/platformio/platform-atmelsam/archive/refs/tags/v8.0.0.zip
board = seeed_wio_terminal
platform_packages =
	toolchain-gccarmnoneeabi@~1.90301.0
	-DARDUINO_ARCH_SAMD
	-DEIDSP_USE_CMSIS_DSP
	-DEIDSP_LOAD_CMSIS_DSP_SOURCES
	-DEI_CLASSIFIER_TFLITE_ENABLE_CMSIS_NN
	-D__STATIC_FORCEINLINE=__STATIC_INLINE
	-std=c++17
	-std=gnu++17
	-O3
    -DAZ_NO_LOGGING
;    -DconfigTOTAL_HEAP_SIZE=30720
build_unflags =
	-std=gnu++11
	https://github.com/Seeed-Studio/Seeed_Multichannel_Gas_Sensor#v1.0.0
	https://github.com/Seeed-Studio/Seeed_Arduino_Linechart#v1.0.0
	rlogiacco/CircularBuffer@^1.3.3
    https://github.com/bxparks/AceButton#v1.9.2
    ;https://github.com/lovyan03/LovyanGFX#0.3.10
	; BEGIN Azure IoT dependencies
	https://github.com/SeeedJP/pio-azure-sdk-for-c#1.1.0
    https://github.com/Seeed-Studio/Seeed_Arduino_rpcWiFi#v1.0.5
    https://github.com/Seeed-Studio/Seeed_Arduino_rpcUnified#v2.1.4
    https://github.com/Seeed-Studio/Seeed_Arduino_mbedtls#v3.0.1
    https://github.com/Seeed-Studio/Seeed_Arduino_FS#v2.1.1
    https://github.com/Seeed-Studio/Seeed_Arduino_SFUD#v2.0.1
    https://github.com/ciniml/ExtFlashLoader#0.1.2
    arduino-libraries/NTPClient
    knolleary/PubSubClient
    hideakitai/MsgPack
    bblanchon/ArduinoJson@6.20.1
	; END   Azure IoT dependencies
previously we were getting errors within the individual files/code in the firmware files, but now there are no specific marked errors showing up in the code itself, just this assembly error in the terminal. I would show our exact file set up, but I’m not sure how to upload our current project to this forum post (I can send pictures and copy Paths or specific areas of code if that would be helpful, and you can take a look at the source code I linked for a rough idea of the file set up)
There have been no marked errors in this section of the code (firmware/src/main.cpp) but it’s where I’ve been doing most of the tweaking in the past, so the issue might lie here?
#include "Config.h"
#include "ConfigurationMode.h"
// Storage
#include <ExtFlashLoader.h>
#include "Storage.h"
static ExtFlashLoader::QSPIFlash Flash_;
static Storage Storage_(Flash_);
// Network
#include <Network/WiFiManager.h>
#include <Network/TimeManager.h>
#include <Aziot/AziotDps.h>
#include <Aziot/AziotHub.h>
#include <ArduinoJson.h>
static bool isWifiConfigured = false;
static WiFiManager WifiManager_;
static TimeManager TimeManager_;
static std::string HubHost_;
static std::string DeviceId_;
static AziotHub AziotHub_;
static unsigned long TelemetryInterval_ = TELEMETRY_INTERVAL;   // [sec.]
static unsigned long nextTelemetrySendTime = 0;
* @brief      Printf function uses vsnprintf and output using Arduino Serial
* @param[in]  format     Variable argument list
void ei_printf(const char *format, ...)
  static char print_buf[512] = { 0 };
  va_list args;
  va_start(args, format);
  int r = vsnprintf(print_buf, sizeof(print_buf), format, args);
  va_end(args);
  if (r > 0)
    Serial.write(print_buf);
static void ConnectWiFi()
  ei_printf("Connecting to SSID: %s\n", Storage_.WiFiSSID.c_str());
	WifiManager_.Connect(Storage_.WiFiSSID.c_str(), Storage_.WiFiPassword.c_str());
	while (!WifiManager_.IsConnected())
		ei_printf(".");
		delay(500);
	ei_printf("Connected\n");
static void SyncTimeServer()
	ei_printf("Synchronize time\n");
	while (!TimeManager_.Update())
		ei_printf(".");
		delay(1000);
	ei_printf("Synchronized\n");
static bool DeviceProvisioning()
	ei_printf("Device provisioning:\n");
  ei_printf(" Id scope = %s\n", Storage_.IdScope.c_str());
  ei_printf(" Registration id = %s\n", Storage_.RegistrationId.c_str());
	AziotDps aziotDps;
	aziotDps.SetMqttPacketSize(MQTT_PACKET_SIZE);
  if (aziotDps.RegisterDevice(DPS_GLOBAL_DEVICE_ENDPOINT_HOST, Storage_.IdScope, Storage_.RegistrationId, Storage_.SymmetricKey, MODEL_ID, TimeManager_.GetEpochTime() + TOKEN_LIFESPAN, &HubHost_, &DeviceId_) != 0)
    ei_printf("ERROR: RegisterDevice()\n");
    return false;
  ei_printf("Device provisioned:\n");
  ei_printf(" Hub host = %s\n", HubHost_.c_str());
  ei_printf(" Device id = %s\n", DeviceId_.c_str());
    return true;
static bool AziotIsConnected()
  return AziotHub_.IsConnected();
static void AziotDoWork()
    if(!isWifiConfigured) return;
    static unsigned long connectTime = 0;
    static unsigned long forceDisconnectTime;
    bool repeat;
    do {
      repeat = false;
      const auto now = TimeManager_.GetEpochTime();
      if (!AziotHub_.IsConnected()) {
        if (now >= connectTime) {
          // Serial.printf("Connecting to Azure IoT Hub...\n");
          if (AziotHub_.Connect(HubHost_,
                                DeviceId_,
                                MODEL_ID,
                                now + TOKEN_LIFESPAN) != 0) {
            // Serial.printf("ERROR: Try again in 5 seconds\n");
            connectTime = TimeManager_.GetEpochTime() + 5;
            return;
          // Serial.printf("SUCCESS\n");
          forceDisconnectTime =
            static_cast<unsigned long>(TOKEN_LIFESPAN * RECONNECT_RATE);
          AziotHub_.RequestTwinDocument("get_twin");
      } else {
        if (now >= forceDisconnectTime) {
          // Serial.printf("Disconnect\n");
          AziotHub_.Disconnect();
          connectTime = 0;
          repeat = true;
        } else {
          AziotHub_.DoWork();
    } while (repeat);
template <typename T>
static void AziotSendConfirm(const char* requestId, const char* name, T value, int ackCode, int ackVersion)
	StaticJsonDocument<JSON_MAX_SIZE> doc;
	doc[name]["value"] = value;
	doc[name]["ac"] = ackCode;
	doc[name]["av"] = ackVersion;
	char json[JSON_MAX_SIZE];
	serializeJson(doc, json);
	AziotHub_.SendTwinPatch(requestId, json);
static bool AziotUpdateWritableProperty(const char* name, T* value, const JsonVariant& desiredVersion, const JsonVariant& desired, const JsonVariant& reported = JsonVariant())
    bool ret = false;
    JsonVariant desiredValue = desired[name];
    JsonVariant reportedProperty = reported[name];
	if (!desiredValue.isNull())
        *value = desiredValue.as<T>();
        ret = true;
    if (desiredValue.isNull())
        if (reportedProperty.isNull())
            AziotSendConfirm<T>("init", name, *value, 200, 1);
    else if (reportedProperty.isNull() || desiredVersion.as<int>() != reportedProperty["av"].as<int>())
        AziotSendConfirm<T>("update", name, *value, 200, desiredVersion.as<int>());
    return ret;
template <size_t desiredCapacity>
static void AziotSendTelemetry(const StaticJsonDocument<desiredCapacity>& jsonDoc, char* componentName)
	char json[jsonDoc.capacity()];
	serializeJson(jsonDoc, json, sizeof(json));
	AziotHub_.SendTelemetry(json, componentName);
#include <AceButton.h>
using namespace ace_button;
#include <CircularBuffer.h>
#include <artificial_nose_main_inferencing.h>
#include <Multichannel_Gas_GMXXX.h>
#include <Wire.h>
GAS_GMXXX<TwoWire>* gas = new GAS_GMXXX<TwoWire>();
#include "seeed_line_chart.h"
#include <TFT_eSPI.h>
TFT_eSPI tft;
TFT_eSprite spr = TFT_eSprite(&tft); // main sprite
#define DARK_BACKGROUND 0
#define TEXT_COLOR (DARK_BACKGROUND ? TFT_WHITE : TFT_BLACK)
#define BG_COLOR (DARK_BACKGROUND ? TFT_BLACK : TFT_WHITE)
#include "fonts/roboto_bold_28.h"
#include "images/icon_ambient.h"
#include "images/icon_anomaly.h"
#include "images/icon_coffee.h"
#include "images/icon_no_anomaly.h"
#include "images/icon_whiskey.h"
#include "images/icon_wifi.h"
#define USE_ICONS 1
#if USE_ICONS
const unsigned short* ICONS_MAP[] = { icon_ambient, icon_coffee, icon_whiskey };
typedef uint32_t (GAS_GMXXX<TwoWire>::*sensorGetFn)();
typedef struct SENSOR_INFO
  char* name;
  char* unit;
  std::function<uint32_t()> readFn;
  uint16_t color;
  uint32_t last_val;
} SENSOR_INFO;
SENSOR_INFO sensors[4] = {
  { "NO2", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_NO2, gas), TFT_RED, 0 },
  { "CO", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_CO, gas), TFT_GREEN, 0 },
  { "C2H5OH", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_C2H5OH, gas), TFT_BLUE, 0 },
  { "VOC", "ppm", std::bind(&GAS_GMXXX<TwoWire>::measure_VOC, gas), TFT_PURPLE, 0 }
#define NB_SENSORS 4
char title_text[50] = "";
enum MODE
  TRAINING,
  INFERENCE
enum MODE mode = TRAINING;
enum SCREEN_MODE
  SENSORS,
  GRAPH,
  INFERENCE_RESULTS
enum SCREEN_MODE screen_mode = GRAPH;
int latest_inference_idx = -1;
float latest_inference_confidence_level = -1.;
#define MAX_CHART_SIZE 50
std::vector<doubles> chart_series = std::vector<doubles>(NB_SENSORS, doubles());
// Allocate a buffer for the values we'll read from the gas sensor
CircularBuffer<float, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE> buffer;
uint64_t next_sampling_tick = micros();
#define INITIAL_FAN_STATE LOW
static int fan_state = INITIAL_FAN_STATE;
static bool debug_nn = false; // Set this to true to see e.g. features generated
                              // from the raw signal
void draw_chart();
enum class ButtonId
  C,
  LEFT,
  RIGHT,
  UP,
  DOWN,
  PRESS
static const int ButtonNumber = 6;
static AceButton Buttons[ButtonNumber];
static void ReceivedTwinDocument(const char* json, const char* requestId)
	if (deserializeJson(doc, json)) return;
  if (doc["desired"]["$version"].isNull()) return;
    if (AziotUpdateWritableProperty("telemetryInterval", &TelemetryInterval_, doc["desired"]["$version"], doc["desired"], doc["reported"]))
      nextTelemetrySendTime = millis() + TelemetryInterval_;
      // ei_printf("New telemetryInterval = %d\n", TelemetryInterval_);
static void ReceivedTwinDesiredPatch(const char* json, const char* version)
	if (doc["$version"].isNull()) return;
  if (AziotUpdateWritableProperty("telemetryInterval", &TelemetryInterval_, doc["$version"], doc.as<JsonVariant>()))
static void ButtonEventHandler(AceButton *button, uint8_t eventType, uint8_t buttonState)
  const uint8_t id = button->getId();
  if (ButtonNumber <= id)
    return;
  switch (eventType) {
    case AceButton::kEventReleased:
      switch (static_cast<ButtonId>(id)) {
        case ButtonId::C:
          // Toggle Fan
          fan_state = (fan_state == HIGH) ? LOW : HIGH ;
          digitalWrite(D0, fan_state); // Turn fan ON
          break;
        case ButtonId::PRESS:
          mode = (mode == INFERENCE) ? TRAINING : INFERENCE;
          spr.pushSprite(0, 0);
          break;
        case ButtonId::LEFT:
          switch (screen_mode) {
            case INFERENCE_RESULTS:
              break;
            case GRAPH:
              screen_mode = SENSORS;
              break;
          break;
        case ButtonId::RIGHT:
            case SENSORS:
              break;
            case GRAPH:
              screen_mode = INFERENCE_RESULTS;
              break;
          break;
      break;
static void ButtonInit()
  Buttons[static_cast<int>(ButtonId::C)].init(
    WIO_KEY_C, HIGH, static_cast<uint8_t>(ButtonId::C));
  Buttons[static_cast<int>(ButtonId::LEFT)].init(
    WIO_5S_LEFT, HIGH, static_cast<uint8_t>(ButtonId::LEFT));
  Buttons[static_cast<int>(ButtonId::RIGHT)].init(
    WIO_5S_RIGHT, HIGH, static_cast<uint8_t>(ButtonId::RIGHT));
  Buttons[static_cast<int>(ButtonId::UP)].init(
    WIO_5S_UP, HIGH, static_cast<uint8_t>(ButtonId::UP));
  Buttons[static_cast<int>(ButtonId::DOWN)].init(
    WIO_5S_DOWN, HIGH, static_cast<uint8_t>(ButtonId::DOWN));
  Buttons[static_cast<int>(ButtonId::PRESS)].init(
    WIO_5S_PRESS, HIGH, static_cast<uint8_t>(ButtonId::PRESS));
  ButtonConfig* buttonConfig = ButtonConfig::getSystemButtonConfig();
  buttonConfig->setEventHandler(ButtonEventHandler);
  buttonConfig->setFeature(ButtonConfig::kFeatureClick);
static void ButtonDoWork()
  for (int i = 0;
       static_cast<size_t>(i) < std::extent<decltype(Buttons)>::value;
       ++i) {
    Buttons[i].check();
void setup()
  Storage_.Load();
  pinMode(D0, OUTPUT);
  pinMode(WIO_KEY_A, INPUT_PULLUP);
  pinMode(WIO_KEY_B, INPUT_PULLUP);
  pinMode(WIO_KEY_C, INPUT_PULLUP);
  pinMode(WIO_5S_UP, INPUT_PULLUP);
  pinMode(WIO_5S_DOWN, INPUT_PULLUP);
  pinMode(WIO_5S_LEFT, INPUT_PULLUP);
  pinMode(WIO_5S_RIGHT, INPUT_PULLUP);
  pinMode(WIO_5S_PRESS, INPUT_PULLUP);
  if (digitalRead(WIO_KEY_A) == LOW &&
      digitalRead(WIO_KEY_B) == LOW &&
      digitalRead(WIO_KEY_C) == LOW   )
      ei_printf("In configuration mode\r\n");
      ConfigurationMode(Storage_);
  ButtonInit();
  digitalWrite(D0, INITIAL_FAN_STATE);
  gas->begin(Wire, 0x08); // use the hardware I2C
  tft.begin();
  tft.setRotation(3);
  spr.setColorDepth(8);
  spr.createSprite(
    tft.width(),
    tft.height()); // /!\ this will allocate 320*240*2 = 153.6K of RAM
  spr.fillSprite(BG_COLOR);
  spr.setTextColor(TEXT_COLOR);
  spr.setFreeFont(&FreeSans12pt7b);
	if(! Storage_.WiFiSSID.empty()) {
    isWifiConfigured = true              ;
    spr.drawString("Wi-Fi", 20, 40);
    spr.pushSprite(0,0);
    ConnectWiFi();
    spr.drawXBitmap(320 - 24 - 4, 4, icon_wifi, 24, 24, TFT_GREEN, BG_COLOR);
    spr.drawString("Wi-Fi ... OK", 20, 40);
    spr.drawString("Time sync.", 20, 70);
    SyncTimeServer();
    spr.drawString("Time sync. ... OK", 20, 70);
    spr.drawString("Provisioning", 20, 100);
    if (!DeviceProvisioning()) abort();
    spr.drawString("Provisioning ... OK", 20, 100);
    spr.drawString("Azure IoT Hub", 20, 130);
    AziotDoWork();
    spr.drawString("Azure IoT Hub ... OK", 20, 130);
    AziotHub_.SetMqttPacketSize(MQTT_PACKET_SIZE);
    AziotHub_.ReceivedTwinDocumentCallback = ReceivedTwinDocument;
    AziotHub_.ReceivedTwinDesiredPatchCallback = ReceivedTwinDesiredPatch;
int fan = 0;
void loop()
  if(isWifiConfigured && WifiManager_.IsConnected()) {
  ButtonDoWork();
  AziotDoWork();
  if (mode == TRAINING) {
    strcpy(title_text, "Training mode");
  if (screen_mode != INFERENCE_RESULTS) {
    spr.setFreeFont(&Roboto_Bold_28);
    spr.drawString(title_text, 15, 10, 1);
    for (int8_t line_index = 0; line_index <= 2; line_index++) {
      spr.drawLine(
        0, 50 + line_index, tft.width(), 50 + line_index, TEXT_COLOR);
  spr.setFreeFont(&FreeSansBoldOblique9pt7b); // Select the font
  uint64_t new_sampling_tick = -1;
  if (micros() > next_sampling_tick) {
    new_sampling_tick = micros() + (EI_CLASSIFIER_INTERVAL_MS * 1000);
    next_sampling_tick = new_sampling_tick;
  for (int i = NB_SENSORS - 1; i >= 0; i--) {
    uint32_t sensorVal = sensors[i].readFn();
    if (sensorVal > 999) {
      sensorVal = 999;
    sensors[i].last_val = sensorVal;
    if (chart_series[i].size() == MAX_CHART_SIZE) {
      chart_series[i].pop();
    chart_series[i].push(sensorVal);
    if (new_sampling_tick != -1) {
      buffer.unshift(sensorVal);
    case SENSORS: {
      for (int i = 0; i < NB_SENSORS; i++) {
        int x_ref = 60 + (i % 2 * 170);
        int y_ref = 100 + (i / 2 * 80);
        spr.drawString(sensors[i].name, x_ref - 24, y_ref - 24, 1);
        spr.drawRoundRect(x_ref - 24, y_ref, 80, 40, 5, TEXT_COLOR);
        spr.drawNumber(chart_series[i].back(), x_ref - 20, y_ref + 10, 1);
        spr.setTextColor(TFT_GREEN);
        spr.drawString(sensors[i].unit, x_ref + 12, y_ref + 8, 1);
      break;
    case GRAPH: {
      auto content = line_chart(10, 60); //(x,y) where the line graph begins
      content.height(tft.height() - 70 * 1.2)
        .width(tft.width() - content.x() * 2)
        .based_on(0.0)
        .show_circle(false)
        .value(chart_series)
        .x_role_color(TEXT_COLOR)
        .y_role_color(TEXT_COLOR)
        .x_tick_color(TEXT_COLOR)
        .y_tick_color(TEXT_COLOR)
        .x_auxi_role(dash_line().color(TFT_DARKGREY))
        .color(sensors[0].color, sensors[1].color, sensors[2].color, sensors[3].color)
        .draw();
        spr.setFreeFont(&FreeSans9pt7b);
        spr.setTextColor(sensors[i].color);
        spr.setTextDatum(BC_DATUM);
        spr.drawString(sensors[i].name, 70 + (i * 70), 236, 1);
      spr.setTextDatum(TL_DATUM); // reset to default
      break;
    case INFERENCE_RESULTS: {
        spr.drawString("Outputting sensor data to serial.", 16, 60, 1);
        spr.drawString("Use Edge Impulse CLI on your", 16, 100, 1);
        spr.drawString("computer to upload training", 16, 120, 1);
        spr.drawString("data to your project.", 16, 140, 1);
    default: {
      break; // nothing
  if(millis() >= nextTelemetrySendTime)
    if (AziotIsConnected())
        doc["no2"] = sensors[0].last_val;
        doc["co"] = sensors[1].last_val;
        doc["c2h5oh"] = sensors[2].last_val;
        doc["voc"] = sensors[3].last_val;
        AziotSendTelemetry<JSON_MAX_SIZE>(doc, "gas_sensor");
        nextTelemetrySendTime = millis() + TelemetryInterval_ * 1000;
    ei_printf("%d,%d,%d,%d\n", sensors[0].last_val, sensors[1].last_val, sensors[2].last_val, sensors[3].last_val);
  } else { // INFERENCE
    if (!buffer.isFull()) {
      ei_printf("Need more samples to start infering.\n");
    } else {
      // Turn the raw buffer into a signal which we can then classify
      float buffer2[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
      for (int i = 0; i < buffer.size(); i++) {
        buffer2[i] = buffer[i];
        ei_printf("%f, ", buffer[i]);
      ei_printf("\n");
      signal_t signal;
      int err = numpy::signal_from_buffer(
        buffer2, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
      if (err != 0) {
        ei_printf("Failed to create signal from buffer (%d)\n", err);
        return;
      // Run the classifier
      ei_impulse_result_t result = { 0 };
      err = run_classifier(&signal, &result, debug_nn);
      if (err != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", err);
        return;
      // print the predictions
      size_t best_prediction = 0;
      ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d "
                "ms.): \n",
                result.timing.dsp,
                result.timing.classification,
                result.timing.anomaly);
      int lineNumber = 60;
      char lineBuffer[60] = "";
      for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
        if (result.classification[ix].value >=
            result.classification[best_prediction].value) {
          best_prediction = ix;
        sprintf(lineBuffer,
                "    %s: %.5f\n",
                result.classification[ix].label,
                result.classification[ix].value);
        ei_printf(lineBuffer);
      if (screen_mode == INFERENCE_RESULTS) {
        if (best_prediction != latest_inference_idx) {
          // clear icon background
        #if USE_ICONS
        spr.pushImage(30, 35, 130, 130, (uint16_t*)ICONS_MAP[best_prediction]);
        spr.setTextDatum(CC_DATUM);
        spr.drawString(title_text, 160, 200, 1);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
      sprintf(lineBuffer, "    anomaly score: %.3f\n", result.anomaly);
      if (mode == INFERENCE && screen_mode == INFERENCE_RESULTS) {
        spr.pushImage(160,
                      35,
                      130,
                      130,
                      (result.anomaly > 0.15) ? icon_anomaly : icon_no_anomaly);
      sprintf(title_text,
              "%s (%d%%)",
              result.classification[best_prediction].label,
              (int)(result.classification[best_prediction].value * 100));
      ei_printf("Best prediction: %s\n", title_text);
      // check if we need to report a change in detected scent to the IoT platform.
      // 2 cases: new scent has been detected, or confidence level of a scent previously reported as changed by 5+ percentage points
      if (best_prediction != latest_inference_idx ||
          best_prediction == latest_inference_idx &&
            (result.classification[best_prediction].value -
               latest_inference_confidence_level >
             .05)) {
        if (isWifiConfigured) {
        doc["latestInferenceResult"] = title_text;
          static int requestId = 444;
          char b[12];
        AziotHub_.SendTwinPatch(itoa(requestId++, b, 10), json);
      latest_inference_idx = best_prediction;
        result.classification[best_prediction].value;
  spr.pushSprite(0, 0, TFT_MAGENTA);
  // Uncomment block below to dump hex-encoded TFT sprite to serial **/
    uint16_t width = tft.width(), height = tft.height();
    // Image data: width * height * 2 bytes
    for (int y = 0; y < height ; y++) {
      for (int x=0; x<width; x++) {
        Serial.printf("%04X", tft.readPixel(x,y));
Also: I’ve been able to recompile the source code successfully without making any changes, but we’ve only run into errors when trying to replace the current inference library with the one we’ve made. So it’s not a problem with the source code, but it’s an issue with how we’re tweaking it.
We have literally no experience coding whatsoever but our project and grades hinge on getting this to work. PLEASE advise we’re at our wits end cooked beyond belief completely sauced any and all help would be much appreciated. Thank you.
Windows’ MAX_PATH limitation is biting you on this one.
https://arduino-pico.readthedocs.io/en/latest/platformio.html#important-steps-for-windows-users-before-installing
Hi, we went through that tutorial you linked, but we’re encountering a different error now:
Compiling .pio\build\seeed_wio_terminal\lib353\Seeed Arduino FS\fatfs\ff.c.o
src\main.cpp:210:10: fatal error: artificial_nose_inferencing.h: No such file or directory
* Looking for artificial_nose_inferencing.h dependency? Check our library registry!
* CLI  > platformio lib search "header:artificial_nose_inferencing.h"
* Web  > https://registry.platformio.org/search?q=header:artificial_nose_inferencing.h
  210 | #include <artificial_nose_inferencing.h>
compilation terminated.
Compiling .pio\build\seeed_wio_terminal\lib86b\Seeed_Arduino_LCD\TFT_Interface.cpp.o
*** [.pio\build\seeed_wio_terminal\src\main.cpp.o] Error 1
please advise
Where does this file exist inside your project? Still in
lib/ei-artificial_nose-arduino/src/artificial_nose_inferencing.h
as it was in the original project?
What’s the full platformio.ini now?
doesn’t seem to be located anywhere inn the file except when it’s mentioned in firmware/src/main.cpp as:
I checked that path you provided and instead I see
lib/ei-artificial_nose-arduino/src/artificial_nose_main_inferencing.h
do you think if I change the code in the main.cpp file to:
it would help resolve the issue?
Also here’s our platformio.ini:
platform = atmelsam @ 8.0.0
platform_packages =
	-DARDUINO_ARCH_SAMD
	-std=c++17
	-std=gnu++17
	-O3
    -DAZ_NO_LOGGING
build_unflags =
	-std=gnu++11
    hideakitai/MsgPack
Edit: Made that change and I go these errors:
Assembler messages:
Fatal error: can't create .pio\build\seeed_wio_terminal\liba50\ei-artificial_nose-arduino\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\esp_nn_conv_s8_filter_aligned_input_padded_esp32s3.S.o: No such file or directory
Compiling .pio\build\seeed_wio_terminal\liba50\ei-artificial_nose-arduino\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\esp_nn_depthwise_conv_s16_mult1_esp32s3.S.o
Compiling .pio\build\seeed_wio_terminal\liba50\ei-artificial_nose-arduino\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\esp_nn_depthwise_conv_s16_mult4_esp32s3.S.o
*** [.pio\build\seeed_wio_terminal\liba50\ei-artificial_nose-arduino\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\esp_nn_conv_s8_filter_aligned_input_padded_esp32s3.S.o] Error 1
Assembler messages:
Fatal error: can't create .pio\build\seeed_wio_terminal\liba50\ei-artificial_nose-arduino\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\esp_nn_depthwise_conv_s16_mult1_3x3_no_pad_esp32s3.S.o: No such file or directory
*** [.pio\build\seeed_wio_terminal\liba50\ei-artificial_nose-arduino\edge-impulse-sdk\porting\espressif\ESP-NN\src\convolution\esp_nn_depthwise_conv_s16_mult1_3x3_no_pad_esp32s3.S.o] Error 1
I checked through the files, and there are two files included in liba50 that are very similarly named. If I change those file names to the ones the compiler is looking for, would that help resolve the issue?
please advise
Sounds like this library compiles a lot of files wihch are not meant for the target archtecture (an ARM Cortex chip, not some Espressif RISC-V or XTensa chip) at all. In the original project you linked, the porting folder only has one folder: arduino. All other folders were delted.
https://github.com/kartben/artificial-nose/tree/master/firmware/lib/ei-artificial_nose-arduino/src/edge-impulse-sdk/porting/arduino
Did you just copy in the latest version of edge-impulse-sdk without deleting the not-to-be-compiled files like the example does?
Hi sorry for the late response,
I was able to get in contact with someone IRL who was familiar with VS code and we were able to figure out the issue.
Since the OG code is on the older side, it was trying to connect to ESP-NN library, which is no longer supported by Edge impulse and unable to be compiled. Deleting the ESP-NN/folder found in Arduino/libraries//src/edge-impulse-sdk/porting/espressif/ solved the issue.
Here’s a link on the topic: Seeed Wio Terminal | Edge Impulse Documentation
Thank you so much for all your help!
