I have built and uploaded this over a dozen different times. It’s been a few weeks and I reopened it today to simply change the temp sensor from 1 to 5. Go to rebuild and now getting this error. I have deleted the platformIO folder, it still fails. Here is a copy of the terminal:
CONFIGURATION: https://docs.platformio.org/page/boards/nxplpc-arduino-lpc176x/nxp_lpc1769.html
PLATFORM: NXP Arduino LPC176x (0.1.3) > NXP LPC1769
HARDWARE: LPC1769 120MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
- framework-arduino-lpc176x @ 0.2.9
- toolchain-gccarmnoneeabi @ 1.100301.220327 (10.3.1)
Converting Marlin.ino
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 3 compatible libraries
|-- Servo @ 1.0.0
|-- TMCStepper @ 0.8.8
|-- U8glib-HAL @ 0.5.4
Compiling .pio\build\LPC1769\src\src\gcode\feature\runout\M412.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M24_M25.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M26.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M27.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M28_M29.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M30.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M32.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M33.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M34.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M524.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M808.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\sd\M928.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\stats\M31.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\stats\M75-M78.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M104_M109.cpp.o
Compiling .pio\build\LPC1769\src\src\gcode\temp\M105.cpp.o
In file included from Marlin\src\gcode\feature\runout\../../../feature/../module/stepper/../../feature/../lcd/../module/settings.h:31,
from Marlin\src\gcode\feature\runout\../../../feature/../module/stepper/../../feature/../lcd/marlinui.h:31,
from Marlin\src\gcode\feature\runout\../../../feature/../module/stepper/../../feature/tmc_util.h:25,
from Marlin\src\gcode\feature\runout\../../../feature/../module/stepper/trinamic.h:35,
from Marlin\src\gcode\feature\runout\../../../feature/../module/stepper/indirection.h:73,
from Marlin\src\gcode\feature\runout\../../../feature/../module/stepper.h:48,
from Marlin\src\gcode\feature\runout\../../../feature/runout.h:31,
from Marlin\src\gcode\feature\runout\M412.cpp:28:
Marlin\src\gcode\feature\runout\../../../feature/../module/stepper/../../feature/../lcd/../module/../HAL/shared/eeprom_api.h:27:10: fatal error: ../../libs/crc16.h: No such file or directory
27 | #include "../../libs/crc16.h"
compilation terminated.
*** [.pio\build\LPC1769\src\src\gcode\feature\runout\M412.cpp.o] Error 1
I’m not the greatest at this but watch a lot of tutorials on youtube but I’m clueless. Any help is appriciated. Thanks!
