I’m using the EPS32 TWI library for delivering the CAN message
I made a simple code for streaming & transferring a file over 8 bytes CAN message via the CAN Bus,
my code in c is as follows, however, my question is how to merge the fragmented file without any sequence controller? how do I check the CRC of the receiving file? since the CAN standard has its own acknowledgment, would that be sufficient for such huge streaming of a file?
typedef struct {
union {
struct {
uint32_t extd: 1;
uint32_t rtr: 1;
uint32_t ss: 1;
uint32_t self: 1;
uint32_t dlc_non_comp: 1;
uint32_t reserved: 27;
uint32_t flags;
uint32_t identifier;
uint8_t data_length_code;
uint8_t data[TWAI_FRAME_MAX_DLC];
} CAN_message_t;
#define destinationNode 20000x
CAN_message_t msg;
msg.identifier=destinationNode;
msg.data_length_code=8
File date = file.open("/data.bin");
uint8_t *p=date;
while(p){
char buffer[8];
memcpy(buffer, (p+8), 8);
CAN_transmit(&msg);
p+=8;
