i want to creat new project choose rp3 (i have rpi 4) frame work one choice wiring pi but give this errors
Could not initialize project
PIO Core Call Error: “The current working directory C:\Users\OnurNP\Documents\PlatformIO\Projects\ad will be used for the project.\r\n\r\nThe next files/directories have been created in C:\Users\OnurNP\Documents\PlatformIO\Projects\ad\r\ninclude - Put project header files here\r\nlib - Put here project specific (private) libraries\r\nsrc - Put project source files here\r\nplatformio.ini - Project Configuration File\r\n\n\nError: PlatformIO temporary does not support cross-compilation for WiringPi framework. Please use PIO Core directly on Raspberry Pi”
PlatformIO cannot be used to compile programs for the RaspberryPi using the wiringpi framework from any other host OS / machine than a Raspberry Pi itself or using PlatformIO remote in conjuction with a Pi, as linked in the issue.
