I added BLE to a script that lights up LEDs with a random number,
As is, “randomnumber” is being advertised. I want the number to go out. That number is ‘long’, from 1 to 1,000,000.
If I remove the quotes around “randomNumber” on line 126, I get this message. I think I need to work a ‘long’ or something into the text.
How can I go from “randomnumber” to the random number (= randomnumber)?
Compiling .pio\build\esp32dev\src\main.cpp.o
src\main.cpp: In function 'void loop()':
src\main.cpp:126:41: error: no matching function for call to 'setValue(long int&)'
pCharacteristic->setValue(randomNumber);
In file included from C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLEServer.h:20:0,
from C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLEDevice.h:18,
from src\main.cpp:9:
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:75:7: note: candidate: void BLECharacteristic::setValue(uint16_t&) <near match>
void setValue(uint16_t& data16);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:75:7: note: conversion of argument 1 would be ill-formed:
src\main.cpp:126:41: error: invalid initialization of non-const reference of type 'uint16_t& {aka short unsigned int&}' from an rvalue of type 'uint16_t {aka short unsigned int}'
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:76:7: note: candidate: void BLECharacteristic::setValue(uint32_t&) <near match>
void setValue(uint32_t& data32);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:76:7: note: conversion of argument 1 would be ill-formed:
src\main.cpp:126:41: error: invalid initialization of non-const reference of type 'uint32_t& {aka unsigned int&}' from an rvalue of type 'uint32_t {aka unsigned int}'
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:77:7: note: candidate: void BLECharacteristic::setValue(int&) <near match>
void setValue(int& data32);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:77:7: note: conversion of argument 1 would be ill-formed:
src\main.cpp:126:41: error: invalid initialization of non-const reference of type 'int&' from an rvalue of type 'int'
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:78:7: note: candidate: void BLECharacteristic::setValue(float&) <near match>
void setValue(float& data32);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:78:7: note: conversion of argument 1 would be ill-formed:
src\main.cpp:126:41: error: invalid initialization of non-const reference of type 'float&' from an rvalue of type 'float'
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:79:7: note: candidate: void BLECharacteristic::setValue(double&) <near match>
void setValue(double& data64);
C:\Users\joema\.platformio\packages\framework-arduinoespressif32\libraries\BLE\src/BLECharacteristic.h:79:7: note: conversion of argument 1 would be ill-formed:
src\main.cpp:126:41: error: invalid initialization of non-const reference of type 'double&' from an rvalue of type 'double'
*** [.pio\build\esp32dev\src\main.cpp.o] Error 1
==================================================================================================== [FAILED]
#include <Time.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Tone32.h>
#include<BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define PAUSE 3000 // How long to delay?
#define LED01 26
#define LED02 25
#define LED03 17
#define LED04 16
#define LED05 27
int LEDone = LED01;
int LEDtwo = LED02;
int LEDthree = LED03;
int LEDfour = LED04;
int LEDfive = LED05;
const int BZR01 = 14;
const int BZR02 = 12;
const int BZR03 = 13;
const int BZR04 = 5;
const int BZR05 = 13;
long randomNumber = 0L; // Use the "L" to tell compiler it's a long data type, not an int.
Adafruit_SSD1306 display(128, 64, &Wire, 8); //Declaring the display name (display)
// the setup routine runs once when you press reset:
void setup()
// initialize each of the digital pins as an output.
pinMode(LEDone, OUTPUT);
pinMode(LEDtwo, OUTPUT);
pinMode(LEDthree, OUTPUT);
pinMode(LEDfour, OUTPUT);
pinMode(LEDfive, OUTPUT);
pinMode(BZR01, OUTPUT);
pinMode(BZR02, OUTPUT);
pinMode(BZR03, OUTPUT);
pinMode(BZR04, OUTPUT);
pinMode(BZR05, OUTPUT);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //Start the OLED display
display.clearDisplay();
display.display();
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(1, 1);
display.print("SuperJoe"); //Show the name, you can remove it or replace it
display.setCursor(32, 12);
display.setTextSize(2);
display.println("Monster");
display.setCursor(32, 28);
display.println("Labs");
display.display();
delay(5000);
randomSeed(analogRead(0)); // This seeds the random number generator
long generateRandomNumber()
return random(0, 1000000); // Generate random numbers between 0 and one million
void loop()
// Start with lights off.
digitalWrite(LEDone, LOW);
digitalWrite(LEDtwo, LOW);
digitalWrite(LEDthree, LOW);
digitalWrite(LEDfour, LOW);
digitalWrite(LEDfive, LOW);
delay(PAUSE);
randomNumber = generateRandomNumber();
display.display();
display.println("Random Number:");
display.println();
display.println();
display.setCursor(10, 10);
display.setTextSize(3);
display.println(randomNumber); //Show the name, you can remove it or replace it
display.display();
Serial.println(randomNumber);
BLEDevice::init("Monster Laboratories");
BLEServer *pServer = BLEDevice::createServer();
BLEService *pService = pServer->createService(SERVICE_UUID);
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ |
BLECharacteristic::PROPERTY_WRITE);
pCharacteristic->setValue("randomNumber");
pService->start();
// BLEAdvertising *pAdvertising = pServer->getAdvertising(); // this still is working for backward compatibility
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->setScanResponse(true);
pAdvertising->setMinPreferred(0x06); // functions that help with iPhone connections issue
pAdvertising->setMinPreferred(0x12);
BLEDevice::startAdvertising();
if (randomNumber % 2 == 0) //Is it even? (Divisible without remainder by 2?)
digitalWrite(LEDone, HIGH);
digitalWrite(LEDtwo, HIGH);
digitalWrite(14, HIGH);
tone(BZR01, 1000, 1000);
else if (randomNumber % 2 == 1) //If there's a remainder, it's odd.
tone(12, 1000, 1000);
if (randomNumber % 3 == 0)
digitalWrite(LEDthree, HIGH);
tone(13, 1000, 1000);
if (randomNumber % 4 == 0)
digitalWrite(LEDfour, HIGH);
tone(5, 1000, 1000);
if (randomNumber % 5 == 0)
digitalWrite(LEDfive, HIGH);
delay(PAUSE);
if (randomNumber == 0 || randomNumber == 1) // Is it a prime number?
tone(BZR01, 300, 1000);
tone(BZR02, 500, 1000);
tone(BZR03, 700, 1000);
tone(BZR04, 900, 1000);
tone(BZR05, 1100, 1000);
delay(500);
digitalWrite(BZR01, LOW);
digitalWrite(BZR02, LOW);
digitalWrite(BZR03, LOW);
digitalWrite(BZR04, LOW);
digitalWrite(BZR05, LOW);
delay(500);
delay(500);
delay(PAUSE); // Pause for 3 seconds
