Hello all, I’m struggling for days now… (beginner with platfromIO.
This is just an example sketch from rainmaker, works perfect in Arduino IDE, but in PlatfomIO I get this error: [.pio\build\esp32dev\lib478\RainMaker\AppInsights.cpp.o] Error 1
Terminal:
PLATFORM: Espressif 32 (6.2.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20008.0 (2.0.8)
LDF: Library Dependency Finder ->
Found 33 compatible libraries
|-- ESP RainMaker @ 2.0.0
|-- WiFi @ 2.0.0
|-- WiFiProv @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- SimpleBLE @ 2.0.0
Compiling .pio\build\esp32dev\src\main.cpp.o
Building .pio\build\esp32dev\bootloader.bin
Generating partitions .pio\build\esp32dev\partitions.bin
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Compiling .pio\build\esp32dev\lib478\RainMaker\AppInsights.cpp.o
Compiling .pio\build\esp32dev\lib478\RainMaker\RMaker.cpp.o
Compiling .pio\build\esp32dev\lib478\RainMaker\RMakerDevice.cpp.o
C:/Users/Cees/.platformio/packages/framework-arduinoespressif32/libraries/RainMaker/src/AppInsights.cpp:12:10: fatal error: Insights.h: No such file or directory
* Looking for Insights.h dependency? Check our library registry!
* CLI > platformio lib search "header:Insights.h"
* Web > https://registry.platformio.org/search?q=header:Insights.h
#include "Insights.h"
compilation terminated.
PlatfromIO.ini:
Main.cpp:
//This example demonstrates the ESP RainMaker with a custom device
#include "RMaker.h"
#include "WiFi.h"
#include "WiFiProv.h"
#define DEFAULT_POWER_MODE true
#define DEFAULT_DIMMER_LEVEL 127
//**********PWM SETUP *************
#define PWM1_Ch 0
#define PWM1_Res 8
#define PWM1_Freq 1000
int PWM1_DutyCycle = DEFAULT_DIMMER_LEVEL;
bool dimmer_state = true;
const char *service_name = "PROV_1234";
const char *pop = "abcd1234";
//GPIO for push button
Any help to point me in the right direction is welcome.
