Questions about platform-versions
I’m working on a project, on my desktop-PC, running kubuntu, using VisualStudioCode. The source-code resides on my cloud-server.
Recently I tried to compile my project on my laptop (also kubuntu with VSCode), but that failed. After many hours, I think I found the problem. The desktop uses a platform-version the I somehow installed, but my laptop does not have :
desktop :
PACKAGES: - framework-arduinoespressif32 @ 3.1.3+sha.2952ac93
laptop :
PACKAGES: - framework-arduinoespressif32 @ 2.0.14
Searching this site I found that in the past I had installed a pioarduino version of the platform, but not for this project.
Now my questions :
Does VSCode automatically selects that version for new projects, because my platformio.ini does not specify a version of the platform ?
Are there downsides to use those pioarduino-versions ? I presume not, because AFAICT those are newer than the ones that platformio itself provides.
TIA.
It’s not VS Code but PlatformIO which is is using the installed version with the highest version number when no version is specified ìn the platformio.ini:
If you have used pioarduino in the past this number will always be higher (eg. 53.03.13 > 6.6.0).
If you want to use a specific Arduino Framework version, you have to specify the platform version.
Here you’ll find a list of corresponding platform and Arduino Framework versions as well as pioarduino platform versions: platform-espressif32 versions · GitHub
No there are not. Except it is not an official PlatformIO platform (if this matters to you)
