Hi! I opened my project after a few days tried to recompile without changes and I got the errors below (it’s a partial copy and paste, btw, copying from the terminal doesn’t work properly)
Any clues?
Cheers
Currently on PlatformIO 4.0.0
Processing due (platform: atmelsam; board: due; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/due.html
PLATFORM: Atmel SAM 3.8.0 > Arduino Due (Programming Port)
HARDWARE: AT91SAM3X8E 84MHz, 96KB RAM, 512KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink, stlink)
PACKAGES: toolchain-gccarmnoneeabi 1.70201.0 (7.2.1), framework-arduinosam 4.3.190711
Found 5 compatible libraries
|-- <ArduinoJson> 6.11.2 #815326d
|-- <MIDIUSB> 1.0.4
Compiling .pio/build/due/src/ControlChange.cpp.o
Compiling .pio/build/due/src/Note.cpp.o
Compiling .pio/build/due/src/Patch.cpp.o
Compiling .pio/build/due/src/main.cpp.o
In file included from /Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/char_traits.h:39:0,
from /Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/string:40,
from src/MidiEvent.h:3,
from src/ControlChange.h:3,
from src/ControlChange.cpp:2:
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:243:56: error: macro "min" passed 3 arguments, but takes just 2
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:265:56: error: macro "max" passed 3 arguments, but takes just 2
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
from src/Note.h:3,
from src/Note.cpp:1:
from src/Note.h:3,
from src/Patch.h:3,
from src/Patch.cpp:1:
from src/config.h:1,
from src/main.cpp:6:
In file included from /Users/aekidna/.platformio/packages/framework-arduinosam/system/sam/libsam/chip.h:66:0,
from /Users/aekidna/.platformio/packages/framework-arduinosam/cores/sam/Arduino.h:42,
from src/ControlChange.cpp:1:
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:195:5: error: expected unqualified-id before 'const'
min(const _Tp& __a, const _Tp& __b)
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:195:5: error: expected ')' before 'const'
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:195:5: error: expected initializer before 'const'
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:219:5: error: expected unqualified-id before 'const'
max(const _Tp& __a, const _Tp& __b)
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:219:5: error: expected ')' before 'const'
/Users/aekidna/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/include/c++/7.2.1/bits/stl_algobase.h:219:5: error: expected initializer before 'const'
